1978 - 1996 Big Bronco
BBK TB Questions
Old Jul 31, 2004 | 12:42 AM
GotLift's Avatar
GotLift
BBK TB Questions
Where did you get yours? How much was it? Does it require adjutments or can I bolt in on and go?
Thanks
Old Jul 31, 2004 | 07:27 AM
RTM's Avatar
RTM
I bought mine from summit racing but i found it on line cheaper so summit matched the price. I gave summit the web site info and they may or may not have checked it out but they did match the price. I just bolted mine on a drove it.
Old Jul 31, 2004 | 10:22 AM
BigRedBronc's Avatar
BigRedBronc
I also bought mine from Summit Racing. Installed new TPS at the same time, which requires adjustment to .5-1.0 VDC at idle. You also must set base idle with idle adjustment screw, which is very simple. Once the computer has "learned" the new TB, you must start it with the IAC unplugged. Then you adjust the idle adjustment screw to ~750 RPM. Shut it down, plug the IAC back in, and you are done!
Old Jul 31, 2004 | 08:37 PM
crazed87bronco's Avatar
crazed87bronco
i got mine off ebay its a simple install if you get one look at the gasket and see if it needs replaced or not
Old Aug 1, 2004 | 02:25 AM
GotLift's Avatar
GotLift
How much do they average? I was quoted $220 from Desert Rat today. Is that a lot?
Old Aug 1, 2004 | 11:00 AM
crazed87bronco
no that is cheap on summit its $319
Old Aug 15, 2004 | 10:09 PM
gov2mod's Avatar
gov2mod
Performance increase
Did any of you change just the throttle body and what increase in performance did you notice after you installed it?
Old Aug 15, 2004 | 11:15 PM
crazed87bronco
yes i got better throttle responce and more pick up
