Hmm...new EFI motor, popped in my cam from the dead 300 in, timing gear (note I didn't say gears) and all. Get it running and this is what I hear... www.bigblocksix.com/wildjon3006/SOunds/Whine.wav
If I leave it will it be fine until I'm annoyed enough to change the crankshaft timing gear from my old motor in, or is it one of those "get that sucker out of there ASAP" type of situations? I'm about to take a nice looooooong drive down to Statesboro tommarow or Monday depending on whether I should change the gear or not. The motor seems to fine, idle is rock steady and it starts easy considering it's being REALLY overfueled. Warning, Turn down your volume before you listen to the clip
actually..when I read his post on Ford Six it wasn't as big and didn't get my attention..and of course I didn't turn the volume down..at least for my system on my puter..it was Extremely loud..
