Expedition keycode location/rap??
Old Aug 14, 2004 | 12:25 PM
alpaca's Avatar
alpaca
Just bought a 2001 xlt, where do I find the keyless entry code?
Where is the RAP module?
Old Aug 14, 2004 | 01:02 PM
xxx609's Avatar
xxx609
Under the dash, above the break pedal, you'll see a box/module with a white strip of tape imprinted with 5 large numbers. Use those numbers to unlock the doors using the keyless entry and to re-program the system (but WITHOUT deleting the factory code) to use your own 5-digit code. Do you have an owner's manual to accomplish this? If so, follow their instructions. Pretty easy.
Old Aug 14, 2004 | 01:08 PM
alpaca's Avatar
alpaca
Thanks, I didn't look there! Watching mauals on ebay. I downloaded Lincoln info on keyless entry which I'm sure is the same EXCEPT for the location of the code!
Old Aug 14, 2004 | 01:18 PM
xxx609's Avatar
xxx609
Per my '02 owner's manual:
"1. Ener factory set code (keypad will illuminate when pressed).
2. Press 1/2 control within 5 seconds of step 1.
3. New your [new] personal 5 digit code. Enter each digit within 5 seconds of the previous one".
Either code should now unlock the driver's door. Pressing the 3/4 button within 5 seconds will unlock all the other doors; I'm not sure about the tailgate.
Old Aug 14, 2004 | 09:19 PM
PaulC's Avatar
PaulC
The tailgate will also be unlocked.
Old Aug 15, 2004 | 04:01 PM
alpaca's Avatar
alpaca
It's easy when you know how/Where! The module is white, on the left hand side, under dash by the parking brake. I wonder if location is different for adjustable pedals?
Old Aug 16, 2004 | 04:09 PM
the4by4freek's Avatar
the4by4freek
Alpaca it in the exact same spot.... look under the dash and over to the left... you'll se it there.
2FordTrucks
Jan 24, 2016 03:12 PM
Gavint
Jun 7, 2015 08:07 AM
rust-n-rods
New Member Introductions
Aug 28, 2014 10:47 PM
Jacob Duncan
Jun 14, 2014 05:37 AM
rap88
Mar 31, 2014 10:08 AM
