Sponsored by: Kumho
Shackle flip problems
Old Aug 13, 2004 | 08:45 PM
DirtysouthZ71's Avatar
DirtysouthZ71
I just installed one on my F-350 tonight and it wont hold spring rate! I got no lift off it? What gives? Its exactly like the ORD flip I put on my Z71. Although for some reason I cant get them to hold up? They just slap the bracket and bottom out.
Tomorrow im gonna yank it in the air with the fork lift and try to get them to press towards the rear.
Old Aug 14, 2004 | 07:43 AM
teds74ford's Avatar
teds74ford
Are you talking about the rear shackle flip? Is it mounted too far forward on the frame? That is the only thing I can think of. Ted
Old Aug 14, 2004 | 12:54 PM
DirtysouthZ71
It seems I cannot load the spring or something? The axle is to far forward and when its the axle is lifted the rear eyes are brought back the rear spring eye is like 10" too high and 4" to far forward. There is no way to pull the down with the load on it. When its hooked up this way it just folds up I dunno what gives maybe the lift spring is too much to get in?
Old Aug 14, 2004 | 03:49 PM
DirtysouthZ71
Figured it out.. This style shackle flip wont work with such a big spring. So back to blocks for now.
Anyone needs a shackle flip for a Ford pm me!
Old Aug 14, 2004 | 07:55 PM
mark a.'s Avatar
mark a.
You need to move your spring hanger about 6" ahead. I like that disc brake set up
Old Aug 14, 2004 | 07:57 PM
DirtysouthZ71
Wont work. The tire will then be underneath the front of the bed.
Old Aug 14, 2004 | 08:26 PM
mark a.'s Avatar
mark a.
Any shackle flip will do that if you don't drop the front down.
Old Aug 14, 2004 | 08:29 PM
DirtysouthZ71
not on longer less arch springs. Which I figured I could get it to work if I loaded it but there is no way to get it loaded. So it didnt work Ill build bigger springs.
