My bronco has ac that blows cool not cold but only on normal ac. I don't think it is low on freon because I used a gauge that shows it in the acceptable range. If you put in max, you don't feel the more powerful air it just stays the same and while driving down the road, it will quit blowing then come back after a while. Any ideas?
if you can get your hands on a set of manifold guages, it wouldn't hurt to get accurate high and low side readings. In the meantime, I am wondering if there is a problem with the blend door/heater core flow valve (whichever the vehicle uses).
