General Automotive Discussion
tie rod
Old Aug 13, 2004 | 01:56 PM
Peach's Avatar
Peach
tie rod
I posted awhile ago in the forum about steering. I didnt get a response so i'll try here. My right tie rod is bad. Has anyone replaced theres. Or know how they cost?
Old Aug 13, 2004 | 02:16 PM
fellro86's Avatar
fellro86
It depends on the model you are dealing with, and where you buy the part. For your 150 on your proflie, the rod end can run between $30 to $60, depending on where and quality of the part. As far as changing it, it can be done at home but be warned, it can be trying to get it off if very rusty. It would need to be aligned after to be sure, as some would say they count threads and measure and this and that, but the only way to be absolutely sure is to set the toe. As for changing it, it is basic, take the nut loose from the tie rod end, take a good sized hammer, hit on the SIDE of the mount where the rod end goes through, this will pop the tapered bolt out, then take the adjuster sleeve bolts loose, and get a pipe wrench and spin the rod end out, keeping in mind the threads are opposing on the two sector halves so that they will pull together when the sleeve is turned. The same process basically applies for the inner tie rod end as well.
Old Aug 13, 2004 | 02:30 PM
Peach's Avatar
Peach
thanks a lot fellro
Old Aug 13, 2004 | 07:25 PM
85e150's Avatar
85e150
You might need a pickle fork tool to separate the rod ends. Buy a cheapo or borrow one as you will probably only use it this one time. You will have to go to an alignement shop as you can never eyeball these to the correct alignment.
Make sure they center the steering wheel....of course, if you go to a decent shop, you won't have to tell them that....
bigcrunch
Nov 1, 2014 01:39 PM
jswartz84
WTB - Parts & other
Dec 16, 2013 11:52 PM
BearFootCustom
Dec 27, 2010 08:23 PM
beartracks
Mar 11, 2008 02:25 PM
old no bed
Apr 26, 2001 02:57 PM
