Offroad & 4x4
High pinion 9"
Old Aug 13, 2004 | 01:50 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
High pinion 9"
Is it possible to flip the 3rd member over on a 9 inch to make it high pinion, and does anyone make the reverse cut gears for them?
Old Aug 13, 2004 | 05:48 PM
bremen242's Avatar
bremen242
There is a company that just started making real HP9s with reverse cut gears..
Currie makes HP9s with 8.8 reverse cut gears..
check this thread out: http://www.pirate4x4.com/forum/showthread.php?t=251619
And no, you can't just flip a 9 and go. You should, but you could probably only run it about 10 mph b4 it burned up.
1jeffm
Mar 5, 2015 11:00 AM
bryanswens
Sep 16, 2007 10:26 PM
oldhalftons
Jan 19, 2005 11:36 PM
Polkat
Sep 27, 2002 06:16 PM
