e40d shifting and speedometer problem
Old Aug 13, 2004 | 09:08 AM
lojo's Avatar
lojo
Here's a brain teaser from heck:
I have a 1991, f250, Xlt Lariat, 4x4.
The speedometer bounces around, and gives false low reading. The tranny "bangs" into 2nd, unless I back off the acceleration. It slips into, and out of, 3rd (in an narrow rpm range), smooth shift into 4th. No tranny codes. No engine codes. New RABS and speed control sensors, new dash cluster, new throttle position sensor - and no change. It is slowly getting worse.
ABS computer? If lever positioning sensor or transmission range sensor, why the speedometer problem? What is a RABS proportioning valve and what, if anything, might that have to do with it?
Do I need the Einstein of mechanics or just a good priest?
Old Aug 13, 2004 | 04:07 PM
Andyman8282's Avatar
Andyman8282
Did you replace the speed sensor itself?
Old Aug 13, 2004 | 09:12 PM
lojo's Avatar
lojo
Yes. Twice!
Old Aug 13, 2004 | 09:29 PM
Andyman8282
I'm sorry man, but that is just crazy, I don't know what to tell you. It just doesn't add up does it?
Anyone else have any ideas?
Old Aug 13, 2004 | 10:40 PM
Hillclimber's Avatar
Hillclimber
I dont know whats up, but if you need a new tranny, I have one that was rebuilt last summer(about 3500 miles) and my engine just lost a valve, I bought another truck today, and am planning to part out my diesel. It is a 91 f-250 4x4 diesel. Im am near portland oregon.
lars
Old Aug 14, 2004 | 04:48 AM
lojo's Avatar
lojo
Call me a glutton for punishement, but I still think it is an electronic problem. Besides, the tranny is reputed to be relatively new. This fact only serves to fill me with an even greater fear and loathing.
Old Aug 15, 2004 | 12:30 AM
FarmApe's Avatar
FarmApe
That is a tough one, and it seems the signs are in fact pointing toward the speed sensor input. Check the wiring and the connections thoroughly, and check your voltage and good grounds (make sure no corrosion) low voltage will cause funny things...
Old Aug 15, 2004 | 11:21 AM
scottya4's Avatar
scottya4
had a problem with my speed sensor and speedo also, I had the abs computer completely over ridden so now i odnt have abs breaks, but it shifts beautifully, better then when i bought it. I also put in a new speed sensor.
Old Aug 15, 2004 | 11:32 AM
lojo's Avatar
lojo
You might be right. I saw nothing in the 'Haynes Manual' (which begs the question: Is there better than miserable piece of work?) having to do with voltage of the speed sensor. Continuity of circuits, much less finding them, is just outside my range of experience and patience. I did manage to back-probe the TPS which checked out.
My tranny man, suggested the Powertrain Control Module (PCM) may have gone south. But wouldn't that show EEC codes? Speaking of Haynes again, where is the PCM? I think it's behind the dash, to the left of the radio. A real nightmare to pull?
Old Aug 15, 2004 | 11:38 AM
lojo's Avatar
lojo
How did you manage to override the ABS computer!?
Old Aug 15, 2004 | 04:38 PM
bonanzace's Avatar
bonanzace
While trying to trace a short in my 92 f150 xlt, I pulled out fuse #8 and got the same transmission symptoms as you and no speedo readout. Might be a long shot but could you have a #8 fuse that is loose?
Old Aug 15, 2004 | 05:52 PM
scottya4's Avatar
scottya4
not sure how he did it, I'm useless when it comes to electrical things.mus be easy he only charged 40 bucks
Old Aug 15, 2004 | 07:04 PM
Andyman8282
That's very true about the fuse. Check all your fuses, that could definty be a cause of all this.
Old Aug 15, 2004 | 11:02 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Search for PSOM, not sure it applies to your truck.
I think it is PSOM, first I thought it was VSOD. Anyway, on some of these trucks the computer gets a signal from the speedometer cluster and a malfunction causes all kinds of problems.
Once again, if you can figure out what I am talking about, I am not sure if it applies to your truck.
That should be clear as mud, just trying to help.
Old Aug 16, 2004 | 03:21 AM
lojo's Avatar
lojo
Yep. One of the first things I tried was switching out the fuses - No good.
