Cps
Old Aug 13, 2004 | 05:52 AM
blackf3504dr's Avatar
blackf3504dr
Unhappy Cps
Went out to start the truck this morning , she fired right up as always then promply died . She'll crank over fine but won't fire and the tack doesn't move , soooo I guess I'll be replacing the CPS today ! Looks like I can get at it from below ( looking at it with my flashlight ) , is that the easiest way ?
Old Aug 13, 2004 | 06:10 AM
BCS_tx_dieselman's Avatar
BCS_tx_dieselman
Yes,you will need a 10 mm socket & extention. Maybe a screw driver to pry it out if it is stuck.
Old Aug 13, 2004 | 06:59 AM
blackf3504dr
Thanks BCS , it looked like the easiest way to get to it . Now if Charlie holds off awhile I mite be able to get it done today !
