91 Exploder - Fuel Pump Relay - Where?
Old Mar 7, 2000 | 07:00 PM
Jason Fiala
Guest
Posts: n/a
I have a 91 Explorer and cannot get the Fuel Pump to stop running with out disconnecting the battery. My current guess looking through both Haynes and Chiltons is that the Fuel Pump Relay is bad. I bought a replacement, but have not been able to locate the current one. Any ideas?
Old Mar 19, 2000 | 03:47 PM
BExplorer's Avatar
BExplorer
If you have the same haynes as me, go see at chapter 4 section 2, there is an illustration. The switch you are looking for is inside the cab, on the passenger side of the trans and on the fire wall. It is under the carpet, so you must pull it a bit.
Good luck
Old Apr 30, 2001 | 05:51 PM
randy02's Avatar
randy02
I have a 92 exploder and i think what your looking for is underneath the power distrabution box, under the hood on the right side. You have to pull the power dist.box out and then pull the relay mount out to pull the relay out from the bottom.
Old May 1, 2001 | 10:50 AM
winfordr's Avatar
winfordr
