302 cams
Old Aug 12, 2004 | 07:24 PM
WrenchHead84's Avatar
WrenchHead84
Question 302 cams
OK, I'm building a wicked 302. Unfortunately, it's not a roller block
I know I can retro fit it, but awful expensive.
What I was thinking about....I want the 302 HO firing order, which is the same as the 351W. I know 302 cams are interchangable with the 351W's. So my question is, changing to a 351W cam/firing order does that affect what balancer I run on the crank?
WrenchHead
Old Aug 12, 2004 | 08:54 PM
Cloim's Avatar
Cloim
No.
Balancer on the crank is dependent upon how the crank was balanced. You don't change the balancer weight unless the entire rotating assembly (crank, rods, pistons, connecting rods, balancer, flexplate/flywheel) is rebalanced.
Cam will only affect firing order.
And for what it's worth, I'd switch to the 351/5.0ho firing order too. From what I hear it's better that way.
Old Aug 13, 2004 | 12:53 PM
cmlind's Avatar
cmlind
My new cam in my 302 for the mustang changes the firing order. Haven't got it together yet, but my machine shop says good things about it.
Old Aug 14, 2004 | 09:24 AM
JoeDaddy15's Avatar
JoeDaddy15
I finally got my rebuilt shortblock finished and running, and it has the HO cam. Runs good without any problems.
Old Aug 15, 2004 | 02:08 AM
yellowjeep76's Avatar
yellowjeep76
i rebuilt my 90 5.0 and the lunati cam i used changed the firing order to the 302 ho/351. Comp cams do the same i believe. I think its a pretty common practice with aftermarket cams but i'm no expert.
Old Sep 2, 2004 | 03:42 PM
Diggie's Avatar
Diggie
Newbie question: When using these cams and changing the firing order, is it as simple as re-routing the distributer wires to the different plugs or do the injectors and computer have to be changed as well? I have a 1991 speed density intake.
Thanks
Old Sep 2, 2004 | 08:06 PM
Cloim's Avatar
Cloim
Thanks
Trucks are bank fired. Injectors fire 4 at a time. Ford used the same wiring on 351's as 302's. You don't need to mess with the injectors.
If you had an engine with sequential fired injectors, then you would need to change them to match the firing order.
Just change the plug wires. Don't mess with the injector wires.
As for the computer... Ford speed density isn't all that it could be. But as long as the cam is compatible with it, then the firing order doesn't matter.
Sherlock
Aug 4, 2006 12:07 AM
bootie
May 13, 2005 06:28 AM
WrenchHead84
Dec 9, 2003 12:39 PM
WrenchHead84
Jan 27, 2002 07:07 PM
WrenchHead84
Aug 25, 2001 03:18 PM
