Sponsored by: Auxito
F150 Pcm Diagnostics
Old Aug 12, 2004 | 01:53 PM
fireman77's Avatar
fireman77
Can you tell me how to put the ECA,PCM or whatever the computer is called into diagnostic mode to read out the codes without having to procure an expensive scanner on my 1997 F150 Pickup? My Check Engine light has come on intermittantly but is on constantly now.
Old Aug 12, 2004 | 02:55 PM
wgotthardt's Avatar
wgotthardt
If you live near an Autozone, they'll scan it for you (except in CA, where you can 'rent' the OBD scanner for free).
http://www.autozone.com/servlet/UiBr...ayStoreLocator
Cheers, Wm.
Old Aug 13, 2004 | 01:12 PM
fireman77's Avatar
fireman77
Thanks for the Info Wm. I have found a store in my area and will proceed to check it out. I was thinking there must be a switch or method to make the computer flash the codes via Long and short Flashes of the Check Engine light. I read somewhere on the Net that you can the evaluate the sequence of flashing to determine the OBD Code and Error condition.
Old Aug 13, 2004 | 05:52 PM
gfreek's Avatar
gfreek
You used to be able to do that with GM and Chrysler,retrieve codes with the check engine lite, but am quite sure you can't do it with a Ford.
MONAVIERONJON
Jun 10, 2013 07:17 PM
RAYBURGH
1997 - 2003 F150
Apr 17, 2010 10:27 AM
jeff gammon
Aug 29, 2009 08:27 PM
buckskinfordgirl
Jul 7, 2008 02:14 PM
wroseland
Apr 6, 2008 10:33 PM
