Need help decoding door codes
Old Aug 12, 2004 | 12:11 PM
Meche's Avatar
Meche
I just got a new to me 86 F150 4x4 and I'm trying to figure out what is in it. I know it has an I-6 engine and a NP208 transfer case and what appears to be a rear Ford 9" axle.
My door code says Trans=k Axle=16 and spring=BL
What gear ratio is the front and rear axle, what is the rear axle 9" or 8" and what are the spring rates?
Thanks,
Old Aug 12, 2004 | 12:44 PM
82F100SWB's Avatar
82F100SWB
Transmission is a C6, axle is a 9" with 3.50 gears. As for the springs, BA only decodes to the engineering numbers, not the spring rates.
Old Aug 12, 2004 | 12:49 PM
ecarter50's Avatar
ecarter50
Trans K - C6 automatic
Axle 16 - Ford 9" with 3.50 ratio, 3750 lbs capacity
My book doesn't give spring rates just part numbers for front and rear springs.
Old Aug 12, 2004 | 02:56 PM
FTE Ken's Avatar
FTE Ken
Try here:
https://www.ford-trucks.com/articles/2003/9.php
Old Aug 12, 2004 | 10:39 PM
82F100SWB's Avatar
82F100SWB
Ken, that decoder is useless for an 80-86, first off it doesnt' have the majority of Codes used back then, and, second, Ford has changed code definitions along the line also. Heck, I don't think it's on the mark for a 96 either...
