Steering column help, please!
Old Aug 12, 2004 | 08:35 AM
stuck's Avatar
stuck
Unhappy Steering column help, please!
Hey Folks,
I've been wrestling the last 3 nights with reassembling my steering column after I replaced the lock lock cylinder housing and tumbler cylinder.
After reassembly and replacing both upper and lower bearings the steering shaft still has way too much play. I've also lost my turn signal cancellation and steering wheel lock.
AAAAAARRRRRGGGGHHH!
Any insight out there, before I fold and take into the shop to have the pros unscrew what I screwed up.
Many Thanks!
Old Aug 12, 2004 | 09:09 PM
mccluck's Avatar
mccluck
what year make is your vehicle. I fixed my ignition switch actuator on my 95 f150 i went to ford dealership and they let me photo copy pages from their shop manual. better pictures and steps than haynes
Old Aug 13, 2004 | 07:28 AM
stuck's Avatar
stuck
It's a '92 F-150. 5 speed.
Old Aug 14, 2004 | 09:29 PM
mccluck's Avatar
mccluck
youshould be able to put your steering wheel back on and turn it to lock it back up as for too much play in the shaft maybe you need some new bearings? or you are missing a retainer clip somewhere don't know what to tell you about the turn signal.
Old Aug 17, 2004 | 03:16 AM
fordman73's Avatar
fordman73
The reasonfor to much play is your shaft maybe worn. ihad the same problem had to put in a different column
bradsblue89
Aug 4, 2014 07:22 PM
Spaught
1947 and Older Ford Trucks
19
Apr 29, 2013 08:12 AM
86BrownFord
Oct 24, 2010 06:37 AM
DestroyerOfWerldz
1997 - 2003 F150
Jul 6, 2010 10:00 AM
viperbluelx
Jan 17, 2008 10:00 PM
