over-heating tried everything
Old Aug 11, 2004 | 11:05 PM
Tazmanian Devil's Avatar
Tazmanian Devil
One of my family members has a 1976 Ford F150 with a 300 six-cylinder and the last few days it has been really getting over-heated. And we have done everything that we have thought of to get the tempture back down to normal. We have put in a brand-new thermastate, added more coolant. And we were wondering if the exhaust system is shot would that make the truck over-heat? If you have any tips please let me know it would really be appreciated.
Old Aug 11, 2004 | 11:12 PM
Mil1ion's Avatar
Mil1ion
I'll move this to the cooling forum.
The professionals in there should be able to help.
This problem could exist with any year of truck
Old Aug 12, 2004 | 01:04 AM
Matts72's Avatar
Matts72
Check your timing, too much advance will cause it to overheat. Occasionally the small pieces that control the vacuum advance in the distributor will become corroded and lodged.
good luck.
Old Aug 12, 2004 | 03:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
Does it have a fan shroud?
Is it boiling over or does the temp gauge just show hot?
Old Aug 12, 2004 | 08:22 AM
73Custom's Avatar
73Custom
Yes a plugged exhaust or damaged muffler will cause it to overheat. Usually is worse when driving faster, and causes a loss of power at the same time.
Has any other work been done recently? Has it been sitting for a long time? Is it worse, or better on the highway? How fast does it overheat?
Marty
Old Aug 12, 2004 | 11:08 PM
captbly's Avatar
captbly
If the radiator has not been touched in over two years. Take it out and take it to a radiator shop and have them clean/rod it.
Old Aug 14, 2004 | 08:34 AM
Mitch in NC's Avatar
Mitch in NC
A fan shroud and a new radiator works wonders. Most shops around here don't want to rod out a 25+ year old radiator. Good luck.
Old Aug 14, 2004 | 09:48 PM
supercab4x4dually's Avatar
supercab4x4dually
A whopped timing chane will make it out of time,and over heat too.Ive had this problem on a couple of 302's.
Mavs
Nov 23, 2014 11:16 PM
53lincoln
Aug 6, 2013 10:00 AM
morethanthis
Jun 26, 2011 02:29 AM
superduper2
1997 - 2003 F150
Dec 29, 2010 11:03 PM
kyleC9959
3.0L V6
Jul 25, 2004 11:19 AM
