Hissing Carb problem
Old Aug 11, 2004 | 10:46 PM
paradochs's Avatar
paradochs
Howdy everyone
All the time now, at a certain rpm I start to hear a hiss. It grows louder (like more air or fluid is going through) as the rpms go up. I was wondering if anyone had a clue as to what this could be. I'm going to get someone to help me later and I'll see if I can tell what area it is coming from.
Travis
Old Aug 11, 2004 | 11:29 PM
Jimbare's Avatar
Jimbare
all alone in the world
it is getting more air thru it at higher r p ms, that is what it is supposed to do. it sounds like you may have an aircleaner that is not seated properly, or one that has no filter installed. either of those will make the normal carb sound louder.
jim
Old Aug 11, 2004 | 11:37 PM
Cracker289's Avatar
Cracker289
Maybe you have a vacuum leak. Does it idle and otherwise run ok?
Old Aug 12, 2004 | 05:15 AM
Boyd1971's Avatar
Boyd1971
Did you check for a snake on the intake ?
Old Aug 12, 2004 | 11:11 AM
paradochs's Avatar
paradochs
Yeah, it runs and idles fine, just sounds kinda odd.
Old Aug 12, 2004 | 11:15 AM
BB's Avatar
BB
Has it always done this or did it just start? Autolite carbs. are hissy compared to others. Are you running an open element air cleaner?
Old Aug 17, 2004 | 08:30 PM
baitmaster's Avatar
baitmaster
I used to run an open paper air filter on my 390. The hissing got a little quieter with a K&N, but I didnt like to listen to it. This was with both the 350 cfm and the 500 cfm 2bbl. I now have a Holley 4bbl and the Ram Air setup. Mo' power, quiet, and looks killer.
Old Aug 18, 2004 | 12:45 AM
welldiver's Avatar
welldiver
I don't mean to hi jack your tread, but Baitmaster where did you get the ram air set up from, any pics.
Old Aug 20, 2004 | 10:03 PM
baitmaster's Avatar
baitmaster
ramair box
Welldiver, I do have pix, but dont remember the company name. I will find it, I remember they are located in Ontario, Canada. If you look in the ads in some of the HotRod, and performance mags, you will see their ad. I'm not sure how to get the pix to you, I have them on the 'puter.
papatango
Jan 9, 2015 09:50 AM
Daggermouth
Dec 9, 2010 02:09 PM
madtom
Dec 14, 2009 07:10 PM
F250Growler
17
Nov 11, 2008 03:49 PM
Captain Nemo
15
Sep 11, 2006 04:53 PM
