cluster swap ???
Old Aug 11, 2004 | 07:41 PM
pete-the-toolman's Avatar
pete-the-toolman
cluster swap ???
I Need To Know What's Involve To Replace My Original Cluster For A Used Cluster With A Rpm Gage . Is It Simple A Just Pluging The New Cluster ? Do I Have To Get The Cluster Or The Key Reprogram At The Dealer ,is There A Easy Way To Do ??
Thanks
Old Aug 11, 2004 | 07:43 PM
pete-the-toolman
Sorry My Truck Is A 2000 F150
Old Aug 11, 2004 | 09:33 PM
Dealford's Avatar
Dealford
Welcome to FTE!
There are many that are plug & play, but some guys have found a difference in the wiring plugs on the harness.
Have a real good look at what's in your truck before you buy the used one. If you get to remove the used one from the donor truck, that's better. That way you'll get to see both trucks wiring harnesses & determine if they are the same.
AL.
