Aerostar Ford Aerostar
General tranny question....
Old Aug 10, 2004 | 10:44 PM
cookkd's Avatar
cookkd
I purchased a '91 3.0 several months ago to build up and restore with parts from my '90 Eddie Bauer.
The '91 has real poor accelaration at the low end. Could a bad vacuum modulator be causing this? Also, what exactly does the modulator do?
Thanks,
Klaus Cook
Houston Texas
(91 3.0 XLT extended (132k) and 90 3.0 Eddie Bauer extended (252K)
Old Aug 10, 2004 | 11:37 PM
lasher's Avatar
lasher
my understanding is that the modulator helps it to shift smoothly. mine was bad years ago and it would kindof bang through the gears. donno if it would cause your problem.
Old Aug 15, 2004 | 06:50 AM
SgtJoe's Avatar
SgtJoe
The vacuum modulator measures engine load and controls upshifting. When the modulator goes bad, the transmission will typically shift at high RPM's. To see if it is bad, pull the hose off and see if there is any trans fluid in it. Presence of fluid means it's bad. Easy to change, and runs about $20.
