OBD II Code P0402
Old Jul 10, 2001 | 10:52 PM
pstapler's Avatar
pstapler
OBD II Code P0402
Mystery code P0402!
I've done everything short of replacing cat assembly and exhaust. I have replaced the EVR, had the EGR checked, had the computer re-programmed, and replaced both downstream O2 sensors.
Any other things I might try?
Does anyone sell an after-market cat system for '96 Explorers' with a 5.0? Does anyone know the approximate cost from Ford? Or is there a way to check if the cats are clogged? Pressure from the exhaust feels about normal (hand over tail pipe) compared to my '98 Expedition.
TIA
Patrick
Old Jul 11, 2001 | 01:03 AM
knuckles's Avatar
knuckles
OBD II Code P0402
The cats & downstream O2 sensors have nothing to do with a P0402 code.
Here's what Ford says can set a P0402:
Diagnostic Trouble Code (DTC) P0402 indicates that self-test has detected EGR flow.
Possible causes:
-- Non-seated EGR valve.
-- Damaged EGR valve.
-- Damaged EGR Valve Position sensor.
-- Plugged or pinched EGR valve vacuum hose.
-- Plugged or iced EGR Vacuum Regulator solenoid vent.
-- EVR circuit shorted to GND.
-- Damaged EGR Vacuum Regulator solenoid.
-- Damaged PCM.
Since you've addressed the EGR/EVR end of the problem, you might want to look at the EVR circuit and the EGR/EVR vacuum hoses.
If they all ck out ok, the PCM is *probably* faulty.
Old Jul 11, 2001 | 08:56 PM
PAJ's Avatar
PAJ
OBD II Code P0402
cixelsyd
1997 - 2003 F150
Jul 12, 2013 08:46 AM
djones35
Aug 30, 2012 01:22 AM
bbsitum
1997 - 2003 F150
Mar 29, 2012 07:02 PM
wildstang
Sep 3, 2008 09:36 PM
ynot2244
Sep 28, 2005 10:35 AM
