A4WD problem
Old Aug 10, 2004 | 12:37 PM
Rock Hayag's Avatar
Rock Hayag
A4WD problem
97 Expedition, 4.6l, 17" tires
According to the manual you can switch from 2wd to A4wd for speeds up to 55 miles an hour.
I've never allowed my speed to go up to 55mph when switching.
NOW...I can only switch to A4WD from a halt. Then when I move the truck from the halt while turning it's like the front wheels aren't engaging and there is resistance. Anyways, if I travel on the road at any speed past 40MPH that's when the A4WD light begins to blink intermittently.
Does anyone have a clue as to what the problem is??
Thanks, Wheeler AAF, HI
Old Aug 10, 2004 | 01:24 PM
MOOK929RR's Avatar
MOOK929RR
The tension you feel in the front wheels is the limited slip. They are engaded in 4 wheel drive, but when the limited slip kicks in, its hell on the steering. Explaining how 4WD and limited slip works is extensive, better off looking it up here, just do a search:
http://www.howstuffworks.com/
As for the blinking light, ive never seen that, no idea...sorry.
Old Aug 11, 2004 | 07:48 AM
FarmLaw's Avatar
FarmLaw
Mook,
Stock expeditions do not have a limited slip in the front axle, but only in the rear axle (if they have one at all; it was an option). Additionally, engaging 4wd doesn't have any effect on the operation of a limited slip; limited slips are automatic in their operation.
Rock,
Where do you feel the resistance? In the steering wheel? Does it pull more to one side than the other? What kind of surface are you on when trying to engage the 4wd? Nothing hard and dry, right? The resistance while turning sounds like you have 4wd engaged when on a surface with too much traction, and the 4wd is causing the tires and drivetrain to bind.
Does the A4wd light blink only over 40 when it is turned to A4wd, or even when it is set to 2wd?
Old Aug 11, 2004 | 12:49 PM
Rock Hayag's Avatar
Rock Hayag
Farmlaw,
Thanks for the reply. Resistance is felt just as I turn either slightly left or right. During this time it feels as if something is binding like the wheels are attempting to turn of course with resistance.
From a halt and driving straight the A4WD light begins to blink after about 35-40 mph. I really feel that the A4WD is not engaging if needed. Thanks again. Oahu Hawaii
Old Aug 11, 2004 | 03:47 PM
99_EB_EXPY's Avatar
99_EB_EXPY
I have a fulltime A4WD Expy. About a year ago, I was getting a surging under medium & heavy acceleration on hard road surfaces. What it felt like was the transfer case was engaging and then disengaging the front drive train very rapidly. Finally the A4WD idiot light started blinking, so I took it in under extended warranty plan. They changed out some sort of speed sensor, and that fixed the problem. I'm not sure which sensor it was though, I could find out for you if you like.
Old Aug 11, 2004 | 03:52 PM
PaulC's Avatar
PaulC
Have you ever changed the transfer case fluid?
Old Aug 11, 2004 | 04:07 PM
Rock Hayag's Avatar
Rock Hayag
Thanks, I can look up the speed sensor and I did have the front differential fluid changed out by a Seattle Ford Dealer 1 1/2 years ago and have since moved to Hawaii. I am thinking of just having a lube place chnage out the diff fluid and continue to diagnose from there. Thanks again.
Old Aug 12, 2004 | 08:46 AM
PaulC's Avatar
PaulC
Ok, but I'm referring to the transfer case, not the differentials.
Old Aug 12, 2004 | 01:27 PM
Rock Hayag's Avatar
Rock Hayag
Probably not, that wouldn't be the same as transmission would it?
Old Aug 12, 2004 | 03:27 PM
buzzard's Avatar
buzzard
No, but uses the same fluid.
Old Aug 12, 2004 | 05:24 PM
the4by4freek's Avatar
the4by4freek
If your AWD light is blinking you can probably put $$$$ on your speed sensor.
Old Aug 12, 2004 | 07:41 PM
Rock Hayag's Avatar
Rock Hayag
Thanks, I'll check that against the Chilton Manual as far as location. The dealer has asked me "Which one?" the front or rear. WHich one? I imagine the front one right? I also don't think that the transfer case oil has ever been checked or changed out. COuld it also be the so called halls effect sensor? Thanks again. Sunny near Honolulu
Old Aug 13, 2004 | 10:32 AM
the4by4freek
Yes it is the same thing as the hall effect sensor. One is easily accessible and the other is behind the T-case shift motor. Neither one is really tough to get to though. The T-case motor drops out with three bolts. Mine has been out for almost 2 yrs. If I need 4WD I'll just put it in 4WD. I haven't had any problems to date and we got 14+" of snow last year on one storm.
Old Aug 13, 2004 | 12:57 PM
Rock Hayag's Avatar
Rock Hayag
So did you have to take off 1 or 2 halls effect sensors?
Old Aug 13, 2004 | 01:02 PM
the4by4freek
There are 2 on the t-case. Only one is bad. They should read 20 ohms check your resistance with an ohm meter and it will tell you which one is bad.
