Offroad & 4x4
Better ride
Old Aug 9, 2004 | 11:29 PM
Matt66's Avatar
Matt66
Better ride
What can you do for a better, smoother ride. I know I am not exactly driving a Lincoln, but anything could help. I have a 79 F-150 Supercab 4x4 with a leafspring, solid axle front end. It is used mostly for a daily driver/tow vehicle. The only offroading it sees is my driveway. 2 inch is about the most I would want to lift it.
Thaanks, Matt
Old Aug 10, 2004 | 01:19 AM
ivanribic's Avatar
ivanribic
You're sure it's an F-150 and it has leafsprings up front? If so something is goofy here . . . F-150's should have coils up front. If they are leafs how many per pack?
Typically the leafs ride pretty poor compared to a coil spring. You can have a spring shop custom make a set which use more leafs, but thinner so they flex a little better. Downside is this gets pricey and still doesn't improve your ride very dramatically.
Old Aug 10, 2004 | 07:07 AM
fishmanndotcom's Avatar
fishmanndotcom
to start out....try removing some leaves from all your packs. this always helps and it lowers the truck a lil bit! be careful though on the back! i wouldn't remove more than one leaf from your rear packs if you still tow/haul with it. also throw down the money and get a good reputable set of shocks! that always seems to help!
-cutts-
Old Aug 10, 2004 | 07:09 AM
bremen242's Avatar
bremen242
old supercabs have leafs & low pinion Dana 44s. Don't ask me why..
Old Aug 10, 2004 | 07:29 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yeah, Bremen is right. I crapped my diggers when I first saw it too. The 1/2 ton four-wheel-drive supercabs used leaf springs in the front. You'd be surprised at how many true 'Ford people' don't know that. I only found out about 4 years ago and I've been a 'Fordaholic' my whole life.
Cody
In reponse to the question; you've got a leaf-spring vehicle. You don't drive a Lincoln.....hey, it's easy to lift, though!!!
Old Aug 10, 2004 | 10:26 AM
ivanribic's Avatar
ivanribic
Now I'm really confused. All the supercab F-150's around here have coils . . . I was just looking at one this weekend, it was a 78.
Fishy, if it uses the same setup as the F-250 then you only have 2 leafs up front which doesn't really leave you much to pull there.
Old Aug 10, 2004 | 11:51 AM
fishmanndotcom
o yea! i forgot stock packs only come with 2 leafs to begin with!!! you are right those front springs are dad-gummed STIFF! you might try to find a set of rear leafs from and old chevy 1/2 ton! i can't remember the years but they bolt right in and offer a MUCh better ride!
-cutts-
Old Aug 10, 2004 | 12:00 PM
proeliator's Avatar
proeliator
Custom leaf packs using more, thinner leaves. Order them to give you the two inch lift you want. Problem solved.
Old Aug 10, 2004 | 12:32 PM
95-F-350-4x4's Avatar
95-F-350-4x4
sounds like you need a custom airbag suspension or a 4 link. pricey but a smoother ride than a leaf spring.
Old Aug 10, 2004 | 01:31 PM
proeliator's Avatar
proeliator
4 link for a pavement pounder/tow rig!? That wouldn't be a good idea. Somebody has hard core offroad rigs on the brain
Old Aug 10, 2004 | 01:53 PM
95-F-350-4x4
LOL my bad! yeah scratch that idea.
Old Aug 10, 2004 | 02:50 PM
teds74ford's Avatar
teds74ford
Ivan, according to what I have found out, the 150 and 250 used the same frame and all, just different axles. Maybe the rear springs are a little different. In all, though, they are the same. Weird. Of course, now they use ifs and solid axle between the trucks, back then it was coils and leaves. I guess ford it so rich they can afford to tool up 2 sets of trucks
Old Aug 10, 2004 | 07:49 PM
Matt66's Avatar
Matt66
It is a 150 it has two leaves up front with 5 lug axles. The frame is actually going to be a transplant for a 66 crew cab project I have going on. I wanted to upgrade to power steering, power disc brakes, etc. Plus, I figured if I am going to have a solid axle it should be 4 wheel drive and not a single i beam, 2 wheel drive.
Why woudn't air bags and a 4 link be good for a driver tow vehicle? They use bags on big trucks, don't they? Or is it just the 4 link part of it that woudn't be good?
Matt
Old Aug 10, 2004 | 09:43 PM
fishmanndotcom
NO, i am talking about using rear leafs in the front! it works very well!
-cutts-
Old Aug 11, 2004 | 09:58 AM
ivanribic's Avatar
ivanribic
Well sure enough this got me curious so I stopped to check on an F-150 Supercab yesterday and it did have the leaf springs (exact same horrible springs as the F-250). I'm going to have to drive back out to CDA, Idaho this weekend and have a look at that truck again to see if it's a custom hack job or what. Who knows, maybe they lengthened an F-150 frame to stick a supercab on it.
Fishy, when ho did the rear springs up front did he have to move the shackles back? They're longer springs, right?
