Sending unit/fuel pump
Old Jun 16, 2001 | 10:25 AM
93XLT's Avatar
93XLT
Has anyone replaced the sending unit/fuel pump in a 93 4dr 4wd??? Is it a tough job? The gas gauge always reads empty and the truck has 125,000 miles so I want to replace the pump as well.
Old Jun 16, 2001 | 08:41 PM
CobraXP's Avatar
CobraXP
I don't know about a 94, but my 97 was fun to get under. I jacked the rear of the truck up as high as I could(and still feel safe under it) then dropped the tank. I believe the pump is on the top of a 94 also. Then it was just a matter of unplugging the wiring harnesses, 3 bolts and re-installing. The hardest part was just being able to get the tank back up and lined up without crimping any of the wiring harness.
Good luck...
Old Aug 3, 2001 | 12:45 AM
campduck2000's Avatar
campduck2000
I replaced the fuel pump in my '92 Explorer and the hardest part was undoing the fuel lines you need special tools which are plastic to slide into the fittings and then try to slide off the line. the first line caome off real easy the second one was a little tougher. All in all I had it done in 1 afternoon, not a tough job just ime consuming. If you have a air impact wrench it will go alot quicker. The 2 bolts for the skid plate and the support strap by the drive shaft you'll need a ratchet for. Good Luck
Old Aug 3, 2001 | 01:29 PM
jiannello's Avatar
jiannello
I just got done replacing the sending unit on my '93. I agree that disconnecting the fuel line is the most frustrating part. I have found that if you use a metal tool instead of the plactic it goes a lot quicker. I had to go to Napa to get my tool as most stores carry the plastic tool.
Good Luck,
P.S. it goes easier if you run the tank down to 1/8 of a tank or less.
Old Aug 3, 2001 | 09:05 PM
douglapd's Avatar
douglapd
xavier9480
Jul 27, 2017 07:42 PM
lildobr
Vehicles for Sale
Jun 15, 2017 02:45 PM
SuperDutyScaler
1997 - 2003 F150
Apr 5, 2015 01:30 PM
John_1953
Sep 8, 2005 04:49 PM
bradleyj
Sep 19, 2003 12:14 PM
