Cherry bomb v.s Flowmaster
Old Aug 22, 2004 | 01:39 AM
optikal illushun's Avatar
optikal illushun
mufflers are over rated. i had a glasspack/thrush pack on and sounded like poo...went with a flowmaster 40 with duals and it was ok but i bent the pipes so i did a turndown and i loved it but to quiet...throw a 45* bend and an echo tip after the FM and it was louder but the dam pipe rusted out so i just got a new piece of 3 foot pipe...45* bend and used the echo tip agian...much better and louder. sounds so nice...i get plenty of compliments on it...
Old Aug 22, 2004 | 01:43 AM
systemofadowntox's Avatar
systemofadowntox
i had a 24" cherrybomb on my 1970 for d w/ a 300 in it. whent to the muffler shop and had 2 1/2 pipe and a 1 chamber flowmaster put on it w/ no tips at all sounds real good
Old Aug 22, 2004 | 01:52 AM
RomerB2's Avatar
RomerB2
i have a 90 bronco II and have gutted the cats and taken off the muffler with a side swept pipe and it sounds awesome, i have people ask me what i have under the hood and when i show them it's crap lol, but i say no muffler gut the cats all the way through and it has a nice rumble, kinda reminds me of a dragster, just w/o the HP
Old Aug 22, 2004 | 09:48 AM
thecowboy's Avatar
thecowboy
checkyoursix quesrion
how loud is the 40 in your thuck ?
thanks
Old Aug 22, 2004 | 12:14 PM
checkyoursix's Avatar
checkyoursix
Mine is about as loud as a mellow v8. To me it sounds just right. I think it echoes off the ground and back into the bed with the turn down. just make sore it is not blowing in your rear shock.
Old Aug 23, 2004 | 03:51 PM
wook540's Avatar
wook540
I have a 2 1/4 flowmaster 40 on my 96 f150 but i took the second cat off. It sounds deep and mellow, like a v8.
Old Aug 25, 2004 | 09:57 AM
dmccubbi's Avatar
dmccubbi
I removed the second cat and went with 3" pipe into a 40 series FM with a 3 in. turndown coming out. Sounds like v8 at idle and deisel when you get on it
Old Aug 25, 2004 | 01:30 PM
thecowboy's Avatar
thecowboy
did yall go with turn downs after the flowmaster or keep the stock tail pipe that exits behind rear wheel.
Old Aug 25, 2004 | 01:32 PM
thecowboy's Avatar
thecowboy
uh, never mine im stupid
Old Aug 25, 2004 | 01:33 PM
thecowboy's Avatar
thecowboy
are the 40's very loud in the cab?
Old Aug 25, 2004 | 02:32 PM
optikal illushun
mine resonated pretty bad but the dump ended right after the begining of the box...
Old Aug 25, 2004 | 07:46 PM
thecowboy's Avatar
thecowboy
as long as i can carrie on a normal conversation in the cab im good with it. but i dont want it to loud. should i go with the 50's instead?
Old Aug 25, 2004 | 07:55 PM
  #28
ewellman's Avatar
ewellman
I am thinking about doing something similar. About where is the muffler positioned under the truck and how far back do you run the pipes with the turn downs. I was looking under mine today trying to figure out what I need to do and I noticed that the only hanger after the cat is almost to the rear axle. I wander what will happen if I dump the exhaust that close to the axle. I know it's not good for the shocks. Did you have to modify a hanger to keep them closer to the front?
Old Aug 25, 2004 | 08:14 PM
  #29
thecowboy's Avatar
thecowboy
yeah, good question do i put the turn down pipe right on the muffler or run a pipe off the FM then turn down?
Old Aug 25, 2004 | 11:36 PM
  #30
checkyoursix
Just make it come right out of the muffler. Mine has about a 45 degree angle and it blows down just in front of the axle. I did not need any additional hangars, just the one behind the rear cat. Its not that loud inside the cab but you know its there. It just makes it sound like a truck.
