The procedure is in your owners manual. It involves turning key on and off a few time or something like that. My wife has the truck right now...I'll check when she gets home. Gary
Make sure you read the instructions, or have them with you. In order to add a transmitter, you will clear the existing one(s) and reprogram them. So you could potentially lock yourself out if you do it the trial and error method.
Winford
I had to do this the other day. All you need to do is turn the ignition from off to on 8times and the doors will unlock and lock. Within 8 seconds of this happening, touch any key on the transmitter and the locks will lock and unlock, and right away do the other transmitter(provided you have another one). You can program up to 4, but they must be done at the same time. Everytime you do the on/off deal with the ignition, it erases all the transmitter codes. So, there it is.
White 99' Xplorer XLT 4x4, 4.0 SOHC
Bone Stock,leather
