Bronco II Ford Bronco II
distributor cap
Old Aug 9, 2004 | 05:42 AM
tworivers's Avatar
tworivers
distributor cap
I am getting ready to change my dist cap on 89 B2 looks pretty tight back there anyone have any advice or tricks that may make it easier
thanks
Old Aug 9, 2004 | 06:00 AM
tchile's Avatar
tchile
just be sure to mark your wires well and identify where #1 goes on old and new cap.
having long arms is a plus
Old Aug 9, 2004 | 12:59 PM
Help I M Stuck's Avatar
Help I M Stuck
It's doable..just little tight..just a little time and patience goes a long way..however i did find that having a 3 inch body lift on mine maid things a lil easier.
Old Aug 9, 2004 | 02:21 PM
tworivers's Avatar
tworivers
dist cap
Thanks everything is a little tight on B2 I bought it last fall and had to replace the valve cover gasket on the passengers side no room to work at all This is my second bronco first one was a 1968 I bought in 1975 never should of got rid of it
Old Aug 9, 2004 | 09:56 PM
Radioace's Avatar
Radioace
Question Tworivers,
Did the net gasket STOP the leak? Both mine have a very small leak. I notice the current gaskets are cork. I assume rubber is better. I'm about to give it a try when I return from vacation next week. Mine is a 89 2.9FI with 88k miles. I think I may have a little too much blowby in the crankcase. I installed a new pcv valve to no avail. I also have a small leak on the rear main but I can live with that if it stays as slow as it is. I'mresearching an upgrade to a 302 v8. If that gets too messy I will rebuild a 2.9 and trade it out in the next 6 months or so.
Old Aug 9, 2004 | 10:45 PM
tworivers's Avatar
tworivers
gaskets
I used felpro perma dry plus they are expensive but you will only have to do the job once I think I paid about 40 bucks for a pair I still have the drivers side to do it wasn't leaking that bad so I put it off I guess the 2.9's are prone to leaking hope this helps
abe
Nov 12, 2013 01:56 PM
vans
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Oct 4, 2011 05:59 PM
1big79
Mar 17, 2006 10:32 AM
Buckmaster24Fire
1997 - 2003 F150
Jun 1, 2003 01:52 AM
Nathan
May 6, 2002 05:10 PM
