289 crank
Old Aug 9, 2004 | 04:28 AM
bootie's Avatar
bootie
289 crank
hey i want to put my 289 crank and rods into my late model 302 block - am i gonna have any probs with this, do i have to get it linebored or will new bearings be sweet
Old Aug 9, 2004 | 02:30 PM
P51D Mustang's Avatar
P51D Mustang
should be fine.
Old Aug 9, 2004 | 04:00 PM
KwikFord's Avatar
KwikFord
I think You're going to have excessive oil leak. since 289 crank is 2 piece rear main seal and late model block is design for 1 piece rear main seal but I believe it can be made to work. Unfortunately I don't remember what machining process is require.
You're better off asking your local engine machinist and go from there.
Old Aug 9, 2004 | 05:24 PM
bootie's Avatar
bootie
any info out there on that rear seal - what year did they change to the 1 piece seal
Old Aug 9, 2004 | 05:36 PM
KwikFord's Avatar
KwikFord
1983 / 1984 is the year they change to 1 piece seal.
don't forget...289 crank is 28 oz balance and late model 302 is 50 oz balance.
all 351 W is 28oz balance.
I'm sorry, I don't have any additional information about using 2 piece seal crank in late model block and vise versa, but I know it can be done!
Old Aug 10, 2004 | 12:12 AM
bootie's Avatar
bootie
maybe i should just buy a steel crank
Old Aug 10, 2004 | 12:43 AM
KwikFord's Avatar
KwikFord
what do you mean by that?
care to explain!
If you're saying you want to buy aftermarket 289 steel crank. Then it will be made for 2 piece rear main seal.
Like I said before...contact your local engine machinist and hear what he / she has to say.
Old Aug 10, 2004 | 01:56 AM
bootie's Avatar
bootie
sorry i meant a short stroke crank - should clarrify myself - in a way i am my local machinist- i do most of the work -heads, and stuff most of the motors i've built i've just stuffed new rings and bearings into the bottom end and honed up the bore but i do now a couple of machinists but trying to avoid spending money on machinists labour doesn't cost
Old Aug 11, 2004 | 03:55 AM
bootie's Avatar
bootie
steel crank
any one know of anybody who sells a steel crank wiht a 2.87 stroke (289 winsdsor)
BigRobK
19
Dec 9, 2015 05:44 AM
boaterbob
Feb 2, 2013 12:03 PM
Michigan Rick
Oct 2, 2009 01:23 PM
gearhed1971
Jan 8, 2009 11:57 PM
rmalottwtes30
Oct 28, 2006 01:16 PM
