Bronco II Ford Bronco II
87 into 86 B2 engine swap
Old Aug 9, 2004 | 01:41 AM
DonM's Avatar
DonM
Hello;
early 86 b2 manual with tired 2.9l engine, fuel injected without Mass air flow sensor. Found an 87 2.9l with mass air flow sensor for $500. Besides then engine, what other changes must be made? Wiring harness, Brain?
<>< In HIS Service
DonM
Old Aug 9, 2004 | 08:07 AM
Help I M Stuck's Avatar
Help I M Stuck
none..they are the same motors
Old Aug 9, 2004 | 09:26 AM
mrshorty's Avatar
mrshorty
The blocks are the same, but the MAF powered motor will have a different computer, and a different wiring harness. When doing the swap, you'll need to take the computer, wiring harness and all the EEC-IV sensors/switches with you. This may create a few other issues if the new motor is going from an automatic transmission to the manual transmission.
Old Aug 28, 2004 | 12:45 AM
KawiG5's Avatar
KawiG5
I would just swap all external parts from the old one to make the engine identical to the one I was removing. Less chance of any problems.
