Truck won’t start.
Old Aug 8, 2004 | 11:44 AM
f100beatertruck's Avatar
f100beatertruck
Cool Truck won’t start.
I was wondering if anyone out there could give me some ideas on where to look next I’d really appreciate it.
Problem: Went to the store and when I went to leave I turned the key, heard a click then nothing. I tried again and nothing. I also noticed that I lost all power to the truck (dome light is what I noticed). The truck gave no indication of a weak or dying battery.
Observations: When you disconnect the battery and reconnect it, power is restored to the truck.
So far I’ve tried the following:
1. Changed the starter with a remanufactured starter that I has in my garage for the last 4 – 5 years (never used). – No change.
2. Changed the battery with a used one that was good (6mo old) at time of removal – No change.
3. Changed the solenoid with one that worked when I removed it. – No change.
4. Installed new wire from solenoid to starter – No change.
5. Bypassed truck electrical system, hooked directly from the battery to the solenoid to the starter and activated the solenoid with a remote switch – clicking from solenoid.
6. Tried original battery – same result.
I’m charging the second battery up now and I’m going to try it again. I’m at a loss as why I would loose power to the truck like that, and then after I disconnected and reconnected the battery I get it back...
I’ll keep you updated, but I’d appreciate any thoughts that you may have...
Thanks, David
Old Aug 8, 2004 | 01:21 PM
locknkey's Avatar
locknkey
just guessin, could be a bad ground connection to the battery/Solenoid.
Old Aug 8, 2004 | 01:40 PM
jls1973's Avatar
jls1973
could be a faulty neautral safety switch, try going directly from battery to starter once.
Old Aug 8, 2004 | 10:33 PM
f100beatertruck
Locknkey, you got it... Bad ground.
I've yelled at it and made it sit in the corner... Bad ground, bad bad ground...
I tried the charged battery and when that didn't work, I went looking at the negitive cable. It looked brand new at the top, but it was corroded and frayed in the middle where it connects to the frame before it goes to the engine...
Jls1973, I was using a remote starter (just a good sized push button momentery on switch, some wire and some clips) connected directly to the solenoid which bypasses the safety switch... See number 5 in my original post. The mistake that I made was that I eliminated everything on the positive side, but I was still using the negitive side as is...
Thank's for your suggestions,
David
Old Aug 8, 2004 | 11:20 PM
locknkey's Avatar
locknkey
F100beatertruck....Am glad you got it fixed...and am happy to be of help.
Uncle Paul
May 22, 2014 09:33 AM
cityjack
Feb 9, 2014 08:49 PM
Singing River Farm
18
Jan 25, 2014 03:51 PM
Wooticus
Jun 16, 2013 11:57 PM
TwistedPiston
Jan 29, 2012 07:21 AM
