Front Axle
Old Aug 7, 2004 | 10:59 PM
miked79928's Avatar
miked79928
Front Axle
I have an 89 F150 2wd with the independent front suspension. My question is will the Dana 44 IFS front axle bolt right in to my existing suspension components, or will I need to replace everything? I am hoping to convert my beast to 4wd.
Old Aug 7, 2004 | 11:14 PM
FordPerf300's Avatar
FordPerf300
You will need a whole TTB front off a 4x4, you can use your existing coils.
Old Aug 9, 2004 | 09:45 AM
miked79928's Avatar
miked79928
This may sound like a dumb question, but what is a TTB?
Old Aug 9, 2004 | 06:08 PM
FordPerf300
The real name for the IFS front axle is called TTB: twin traction beam. The 4wd one looks like the 2wd with the addition of a gear housing and axle shafts.
Old Aug 9, 2004 | 07:34 PM
miked79928's Avatar
miked79928
Cool. Thanks for clearing that up. The TTB should then just bolt right up to the radius arms and axle brakets, right?
Old Aug 9, 2004 | 07:59 PM
MustangGT221's Avatar
MustangGT221
Look in the "tech articles" section of this website, link on the right.
There is an article on how to perform the swap. Also, using the search engine with various keywords would pop up tons of threads on how to perform the swap.
Old Aug 9, 2004 | 08:25 PM
FordPerf300
Not 100% sure you can use the 2wd arms, like mustang said, search.
Old Aug 9, 2004 | 09:26 PM
MustangGT221
No you can't use the 2wd arms. You need a TTB from hub to hub, it'll bolt right in.
Old Aug 10, 2004 | 09:33 AM
miked79928's Avatar
miked79928
Thanks guys. I guess now all I need to do is locate the right parts.
