Coolant leak
Old Aug 7, 2004 | 04:39 PM
boobrain289's Avatar
boobrain289
Coolant leak
I have a '94 Explorer and I just went out to leave and noticed a steady coolant leak at the rear of the engine by where the starter is mounted. This leak is NOT in the front and travelling to a low spot at the rear. It appears to be coming right from the engine. Any help will be greatly appreciated!!!
Old Aug 7, 2004 | 04:52 PM
Ultramagdan's Avatar
Ultramagdan
Hello boobrain289 and Welcome to FTE!
If you have eliminated a leaking heater hose then I would suspect a intake manifold gasket or a freeze plug.
Old Aug 7, 2004 | 05:14 PM
boobrain289
thanks for the info. Can you elaborate on either of these? Quick fixes/high mechanic bills, etc. ???
