Dashlights, tail-lights intermittent problem
Old Aug 7, 2004 | 12:44 AM
rseyd's Avatar
rseyd
Intermittently the dash-lights, tail-lights, side running lights, and maybe the parking lights go off for a few seconds and then come back on - don't know about the turn signals. The headlights are definitely not effected nor is the high-beam indicator light. The light switch was replaced (different problem) about 4-5 years ago. Does anyone have any idea as to what is causing this crazy problem, PLEASE. THANKS.
Old Aug 7, 2004 | 10:12 AM
HomerWinzlow's Avatar
HomerWinzlow
A couple clues might help, like model and year. Its hard to diagnose a circuit when you dont know what you are working on.
Old Aug 7, 2004 | 10:06 PM
rseyd's Avatar
rseyd
Sorry about that, I feel like an idiot.
Vehicle:
1978 E150 Econoline van with 351 V8, automatic, ps, pb, A/C, and cruise. No power windows, locks, etc. The van also has a dropped floor and tie-downs to accommodate my wheelchair. The wheelchair modifications were done years ago, way before the electrical problem began.
Problem:
Intermittent electrical. The dash-lights, tail-lights, side running lights, and maybe the parking lights will go off for a few seconds and then come back on. It makes no difference whether the van is moving or parked. The headlights are definitely not effected nor is the high-beam indicator light - don't know about the turn signals. This problem began about 3 weeks ago.
Recently, the van has been in the shop twice to try to fix the problem. The first time, a general inspection of the electrical system was done but nothing unusual was found. The battery terminals were cleaned and this SEEMED to help a little. The second time, I had the trailer hitch removed - not the problem.
Thanks in advance to you all.
Old Aug 7, 2004 | 10:12 PM
HomerWinzlow
I dont have any manuals or references dating that far back but several regulars here should have some of the older stuff like Franklin2... it may be a little wait but they may be able to help. If it were a late model I would hazard a guess of a relay, but this sounds more like a grounding problem or switch related on older setups like that. Unfortunatley with the aftermarket installation of the drop floor and wheel chair modifications it may be a real pickle to find.
Old Aug 8, 2004 | 09:03 AM
65CJ5's Avatar
65CJ5
Check the light switch itself. Pull it and check the general conditon. If any doubt they are easy to find and relatively cheap to replace (use a new one, not a used one!). If that doesn't fix it at least it's out of the equation after that.
Old Aug 8, 2004 | 10:34 AM
Dealford's Avatar
Dealford
Also check the headlight switch plug for any signs of burnt or overheated wires. That may have been enough to melt some of the plug body causing a loose connection, etc.,etc.
AL.
Old Aug 8, 2004 | 11:03 PM
Franklin2's Avatar
Franklin2
The headlight switch would definitely be a good place to start. Even though the headlights work ok, the running lamps go through the switch too, but are fed from a different power source.
This is an intermittent problem, which is going to make it tough to locate. Inspection of the headlight plug like the other guys said, would be a good start too. Concentrate on the brown, and tan/white stripe wires going to the switch.
Old Aug 13, 2004 | 01:41 AM
rseyd's Avatar
rseyd
Thank's much, men!
I am having the headlight switch replaced next week. I will also request that they closely inspect the switch plug. Being quadriplegic (auto accident) I'm unable to do these things myself so a local repair shop will be doing the work. It's very frustrating to have to pay someone $72/hour to do something I could once have done myself. I use to really enjoy turning a wrench - before I was injured.
A friend told me that the dimmer switch could be to blame for the problem. Is this possible?? It doesn't sound right to me but I'm pretty much guessing. Should I go ahead and have the dimmer switch replaced too?
THANK YOU
Old Aug 13, 2004 | 02:15 PM
Franklin2's Avatar
Franklin2
I want to make sure of our terminology here. If he means the switch that makes the headlights go from high to low beam, then no, this switch is for the headlights only, which work ok. If he means the dimmer for the dash lights built into the headlight switch(by twisting the ****), this switch only affects the instrument lighting, not the outside running/taillights.
Old Aug 15, 2004 | 01:55 AM
grampztoyz351's Avatar
grampztoyz351
I ran into almost the same problem on my '86 f250 and also noticed nobody else menioned checking system chassis grounds. That is where my problem has.
Old Aug 15, 2004 | 03:05 AM
rseyd's Avatar
rseyd
> replaced too?
This is in reference to the headlight dimmer switch - the foot switch on the floor.
Thanks
Old Aug 30, 2004 | 05:43 PM
rseyd's Avatar
rseyd
I finally got the headligfht switch replaced. Hopefully that will do the trick. I asked the shop to also check the grounds. They said they checked some of the grounds but there are a lot of different grounds and would be a big expense to check them all.
I'll post again when I know how things turn out with the light switch & grounds. Thanks!
Old Aug 30, 2004 | 10:21 PM
Dealford's Avatar
Dealford
When you figure that it's time to throw in a new hi-beam dimmer switch (mounted on the floor), get it from Ford!!! I went through too many aftermarket dimmers in short order and found the Ford switches to last at least twice as long.
AL.
Old Sep 10, 2004 | 07:11 PM
rseyd's Avatar
rseyd
The new light switch (on the dash) was installed a couple of weeks ago and, so far, so good. The problem appears to be fixed! That same switch was supposedly replaced about five years ago. I'm wondering if that was one of those "let's not and say we did" jobs. The original switch worked fine for 21 years so it's hard for me to believe that the replacement switch (genuine Ford part) was only good for five years??
I'm now looking at used vans - only Fords, of course. Do you have any advice for me, especially in regards to which engine and automatic transmission is preferrable? Are there any that should be avoided? - Judging by the prices I'm seeing, I will probably be looking to buy a 1998 or older. Are there any particular model years that are more desirable? Are there any that should be avoided?
Thank you all for your invaluable help.
Old Sep 10, 2004 | 07:20 PM
HomerWinzlow
I highly doubt it was a "lets not and say we did" thing if it lasted another 5 years. Ive seen them go bad in a year so who can tell? Maybe they replaced the switch but didnt replace the connector and the connector has one partially burned pin that created high resistance and eventually caused the new switch to fail prematurely. Perhaps something has been added that loads the circuits more now than originally or the stress of age is just getting to it. In any case I wouldnt complain too much about 5 more years service on a relatively inexpensive part. Many parts today are made in China and other "quality" places where the originals 21 years ago were not.
I would say you are pretty safe with most any of the vans, but I would at least get a V8. The V6 may not have the longevity you seek. The E4OD transmission seems to be one of the better ones for durability. As in any used vehicle purchase, its worth a few extra bucks to get it thoroughly looked over by a trusted technician before making the purchase. One weak spot on the vans was the blower switch. Make sure it is working on all speeds and have the AC checked out good too.
ErrorS
1978 - 1996 Big Bronco
18
Feb 17, 2013 03:15 AM
Ian 2000
Aug 3, 2011 05:57 PM
ajhawkins
1997 - 2003 F150
Mar 29, 2007 03:36 PM
k phillips
Sep 4, 2003 06:42 PM
