1996 Explorer A/C problem
Old Aug 6, 2004 | 11:35 AM
bsl's Avatar
bsl
My air-conditioner on 1996 Ford Explorer stopped blowing cool air. I've purchased an R-134 re-charging kit at Autozone with pressure meter. The pressure check actually showed normal reading (~35), still I managed to add some refrigerant, and the A/C was running good cool air for 2-3 days, but then again it's now warm. What could be the problem? Thanks in advance for your advise!
Old Aug 7, 2004 | 09:50 AM
JerrySimm's Avatar
JerrySimm
If you're running the AC, does the compressor stay on, and is the low pressure line cold? If both of these answers are "Yes", then the problem is not with the refrigerant level or the compressor, or the AC system. It may be in the controls not sending the air flows properly. The Blend Door Fix sticky in this forum may refer to your Explorer model type and it could explain your. I don't have one of the Gen 2 Explorers so I'm not personally familiar with this setup.
