Data plate decoding
Old Aug 5, 2004 | 11:37 PM
RustBucket65's Avatar
RustBucket65
Question Data plate decoding
I was wondering if you guys could help me out with the data plate on my 65 f-100. My chiltons seems to be inept at helping me with it, not even the axle code! So here it is
VIN: F10DD649444
Data plate:115W F100 B81 G C1
5000 172 4000 75
I get that 172 and 4000 are the HP and RPM, but I'm still scratching my head with the others.
Thanks in advance!
Old Aug 6, 2004 | 02:54 PM
kwanderi's Avatar
kwanderi
I think this should do it..
VIN: F10 D D 649444
F10 - F-100
D - 352 engine
D - Assembled in Dallas
649444 - Mfg in Feb 1965
Data plate:115 W F100 B81 G C1
115 - Wheel Base
W - Medium Blue
F100 - 2 Wheel Drive 5000 Lb G.V.W.
B81 - Custom Cab
G - Cruisomatic Transmission
C1 - 3:31 Rear Ratio
Keith
Old Aug 6, 2004 | 11:01 PM
camperspecial65's Avatar
camperspecial65
B = Blue interior....armrests,seat,flr mat and dash if w/o pad and column and wheel....
cs65
Old Aug 9, 2004 | 12:45 AM
RustBucket65
*scratches head* So this engine and trans are not original. It has a 390 with a C6 in it. Strange... everything else is original, the paint, interior, and such. Looks like the drivetrain has been swapped at one time.
Now the only problem I have is the right front bearing. I can't break the nut loose on the spindle to change it. I have it at my shop and even a 200 ft.lbs. impact can't loosen it. I won't be able to drive it till thats fixed. What a bummer.
Thanks for the info guys!
Old Aug 9, 2004 | 09:06 AM
Mike G's Avatar
Mike G
Sure it's a 390, they look just like a 352....???
--Mike
Old Aug 9, 2004 | 07:20 PM
camperspecial65
Check the casting numbers...intake or heads or block....trans tag would be on LH side if it is a cruisematic. An easy way to tell the trans is if the fill tube screws into the RH side of the trans. pan.
Hope this helps, cs65
Old Aug 10, 2004 | 01:24 AM
RustBucket65
OK, so when I had it in the air the other day I took a gander at the trans. It has the big offset trans pan, not the little square one for the C4. Am I right for thinking that a C6 shouldn't be in my 65, right? So I'm pretty convinced that this engine isn't stock, even the color is all wrong for the year. All I have to do is replace the spindle (no easy task as nobody seems to have one) and stop the valve cover leak and I'll be on the road!
Thanks again!
Old Aug 10, 2004 | 09:34 AM
Mike G's Avatar
Mike G
How about replacing the spindles with a pair from a 73-79 model that had disk brakes....
--Mike
