Unusual Idle
Old Aug 5, 2004 | 10:33 PM
k85k03's Avatar
k85k03
Unusual Idle
I was woundering if anybody could help me? I have an 87 F-250 with a 302. Here lately when I let off the gas or push in the clutch to shift. My idle doesn't change or it increases. Somteims getting as high as 2000 rpm. also at times it will go from 800 to 1300 and just go back and forth. I replaced the TPS and cleaned up the throttle assembly with now results. any advice is apreciated. Thanks.
Old Aug 5, 2004 | 11:04 PM
drewcoolness99's Avatar
drewcoolness99
clean out the idler motor?
Old Aug 6, 2004 | 01:49 PM
pfogle's Avatar
pfogle
Clean or replace the IAC it's attached to the side of the throttle body.
Old Aug 6, 2004 | 02:16 PM
iamaguy1357's Avatar
iamaguy1357
Check for anythign bent, and replace them, and also look for any notches or bends in the throttle cable that could cause it from returning to its idle speed.
Krazy351w
Mar 4, 2011 01:09 PM
C90RanMan
Apr 8, 2009 12:15 AM
mykels
Nov 18, 2008 03:36 PM
handsomerob
16
Sep 24, 2007 06:05 PM
marinazaz
Apr 23, 2006 08:57 AM
