need class 5 hitch...
Old Aug 5, 2004 | 07:37 PM
kemerick's Avatar
kemerick
I did not get one on my truck as I thought I could get a better one myself for cheaper. So... what kind should I get?
I am going to towing a buggy on a trailer but I'd like to get a really good one in case I tow something bigger later.
Old Aug 5, 2004 | 08:24 PM
Randy McB's Avatar
Randy McB
Try U-Haul they seem to have goodprices and also offer installation in some areas.Class 4 is good for 10k with weight dist. class 5 is up to 12500. How much weight are you planning on towing?
Old Aug 5, 2004 | 09:31 PM
figmo's Avatar
figmo
Reese makes a very good class 5 hitch. Have one on f-350 dually with a 48 inch extension tube account of a camper in the bed. They come with a bushing to reduce the 2.5 inch receiver to the standard 2 inch if you need to go that route for other applications. We got ours from the Lance Camper dealer in Ontario but am sure there was a mark up on it from them. Might do a web search.
Old Aug 5, 2004 | 09:53 PM
johnsdiesel's Avatar
johnsdiesel
Check out this link, they have good prices (shipping included) and have several different brands.
www.hitch-web.com
Old Aug 5, 2004 | 11:22 PM
kemerick's Avatar
kemerick
I am not too sure as to how much I am gonna tow in the future, but I figute I may as well get the best possible so I don't have to buy one twice :-)
thanks guys.. I'll check out your suggestions tommorrow
Old Aug 6, 2004 | 04:10 PM
bighoss550's Avatar
bighoss550
there is no reason to have a V on anything less than a 450. ur spendin alot of $$$$$$ on a hitch that u can never put to use.
a class V is rated at 14,000lbs. ur gvw is much less than that. also if u are planning on towing that much weight with single rear tires and no air bags, ur in for a real white knuckle ride.
the "adapter" for the 2.5" reciever is horrible!!! it lets the reciever flop all over the place. and if u use the 2" and adapter it defeats the purpose of the class V!!!! u will have to buy the 2.5" solids for upwards of 75 bucks.
i hate to sound condescending, but honestly, get the class IV.... ull be glad u didnt waste ur money BTW, i am speakin from experience, as i have a Reese V on my 550...
Old Aug 6, 2004 | 04:46 PM
johnsdiesel
bighoss550, you said what I was thinking! I totally agree, a class V is unnecessary.
Old Aug 6, 2004 | 05:30 PM
bighoss550's Avatar
bighoss550
there a real pain and i think i may actually take it off, and get a IV. the used V is worth enuf to pay for the IV
BTW, i got my "scamsoil" analysis back today, its in my gallery
i thought about startin another thread about it, but..... why start somethin, right hehe
Old Aug 6, 2004 | 06:38 PM
kemerick's Avatar
kemerick
What do all think of this one from Curt Mfg? - http://www.hitch-web.com/proDescrip....e=314798&OID=8
For $250 shipped seems like a great price... anyone have experience w/ Curt Mfg?
This one from Drw-Tite would be second choice as I am going for maximum capacity - http://www.hitch-web.com/proDescrip....e=314966&OID=8
The beefiest one for my truck from Reese is rated at only 7500lbs - http://www.hitch-web.com/proDescrip....e=314882&OID=8
Old Aug 6, 2004 | 06:56 PM
johnsdiesel
FYI, Draw-Tite and Reese are now the same company. Your first link didn't work. If you can't get it to post, edit it to look like this:
www dot mainpartoflinkhere dot etc...
Old Aug 6, 2004 | 10:12 PM
bighoss550's Avatar
bighoss550
Originally Posted by kemerick
What do all think of this one from Curt Mfg? - http://www.hitch-web.com/proDescrip.asp?ProductCode=314798&OID=8
This one from Drw-Tite would be second choice as I am going for maximum capacity - http://www.hitch-web.com/proDescrip.asp?ProductCode=314966&OID=8
curt makes a great hitch. my goose is a curt, and its the strongest set-up ive seen.
is ur truck a 250? cuz reese is about right on with their "suggestion" if it is.... any more weight than that on a single tire, and u better be hookin up w/ a goose or 5er....
Old Aug 7, 2004 | 08:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Check out my gallery...i
Old Aug 7, 2004 | 11:02 AM
Twin Tritons's Avatar
Twin Tritons
bighoss550,
I was thinking of buying a titan hitch because I tow a pintle hitch equipment trailer that is loaded to the 12,500# rated capacity of my truck. I hook up and disconnect the trailer too many times a day to worry about weight distribution bars, so I thought that the bigger hitch which has a larger weight carrying capacity would be better for my truck. It looks like the hitch attaches further forward on the frame, so the stress is spread out over more of the frame and less likely to cause damage to the truck.
You mentioned that using the 2" adapter that fit quality is poor, but with 2.5" receiver is the fit and finish good? Some of my hauling is off-road so I am not worried about the legalities of weight restrictions and may tow more like 14,000#+ over rough terrain, so I am looking for a good quality hitch. Is the Titan receiver good overall product?
I suppose this question could be over in the towing forum, but since it's already started here....
Old Aug 7, 2004 | 11:24 AM
bighoss550's Avatar
bighoss550
the titan is a great hitch, and its rated at 14K. it does go farther up the frame and its MUCH bigger, and the 2.5 in reciever is a great fit.
with dual wheels the titan is a good choice, but with the singles, its pretty precarious when there's much weight back there.
the problem with 12-15K on a bumper hitch and singles is there is more weight behind the ball than in front. when u jack the brakes in an emergency stop, the wobbley rear end can easily let the high weight on the trailer push the rear of the truck to one side causing an obvious problem......
also the rear is pushed down as the front is picked up which can engage the abs when the fronts slide from the bigger brakes. and the trailer brakes dont activate as fast as u may think. even with the prodigy.
to all who are asking my opinion.....if u gotta haul more than 10,000lbs, u need to be usin a goose neck. the bumper hitch just isnt safe up there
are there really many bumper hitch trailers out there with a 16,000lb rating?? the biggest one i've ever seen was a big car trailer that had a 9000 rating
Old Aug 7, 2004 | 11:37 AM
Twin Tritons
Good points. I have been getting bumper hitch trailers because all my trucks have hitchs, yet none have goosenecks. Also, my F-350 is rated to pull the same either gooseneck or bumper pull, so no load benefit going gooseneck with it on a SRW truck. Time to start looking for a bigger truck, then I can get a bigger trailer, but a bigger trailer may lead to an even bigger truck. Kind of starts a vicious cycle.
With a gooseneck trailer, you are also less likely to have friends ask to borrow it because most trucks don't have gooseneck hitches. BTW, the bigger bumperpull hydraulic dump trailers I have been looking at are 14,000#+ and come equipped with load range G tires.
