Does anyone know if there is one out yet? Now that my truck has an 8" lift and 38" tires it's definately not right. I was hoping I could just ignore it but it looks like it bothers me too much. 2003 F-350 6.0 if that's important. Thanks
I just took mine to the local speedo shop for a re-cal when I went to 315's. I assume that they just change the 60mph point, but it is within tolerating range for me. Cost around $50 IIRC
will superlifts tru-speed converter work for your truck??
Thanks, for the tip. I called them and they said they do have one that will work for the 6.0l. If anyone else is interested I found it online for $185. They say the install should only take an hour. It's only four wires. Thanks Again!
