Sponsored by: Auxito
P171 Code
Old Aug 23, 2004 | 08:37 PM
F2504x4's Avatar
F2504x4
what happened to BlueHarley?
are you one and the same?
Old Aug 23, 2004 | 09:42 PM
blueharley's Avatar
blueharley
Still here. I have not had the light code since cleaning the MAF sensor and checking the hoses etc. I am watching the postings just in case. Thanks for the help on this one.
Old Aug 30, 2004 | 10:05 AM
johnybravo67's Avatar
johnybravo67
I have the same problem w/ my 2001 Sport Trac. P0171 Bank One... fuel too lean. My problem started when I added fuel injector cleaner without the right amount of gas in the tank and fried my O2 sensors ($125 mistake). Replaced both sensors, reset the check engine light and everythig seemed fine for about a day 1/2. Now P0171 has come back. Any thoughts on what it might be? Will clean the MAF as soon as I can find it. Oh yeah, the A/C keeps "cycling" and seems to pull my RPM's down. Probably just low on coolant, but could it be related?
Old Nov 18, 2004 | 12:25 PM
johnybravo67
Follow up to the P171 Code Sport Trak
After changing out oxygen sensors, and a multitude of other things (cleaning the MAF sensor, air filters, etc), it turned out to be a leaking head manifold gasket - i think lower. Truck has 60k miles on it which seems a little early.
Old Nov 23, 2004 | 02:23 AM
danhannah's Avatar
danhannah
F2504by497 -
You saved me about thirty bucks with the spark plug boot elbow idea. Works great - thicker rubber, and it will stand up better to the heat.
Thanks,
Dan
Old Mar 9, 2005 | 05:44 AM
xtraflriome's Avatar
xtraflriome
Question too lean on both bank 1 and 2?
I have both codes p0171 and 0174. It means lean on bank 1 (right side) and lean on bank 2 (left side). Let me think.....Is it getting too much air from the air to fuel ratio? and is it the fuel filter? on my 2002, V6, F150. The mileage reads over 88,000.
Old Mar 9, 2005 | 06:54 AM
projectSHO89's Avatar
projectSHO89
VERY common code combination. Too much unmetered air, i.e. vacuum leak post-MAF.
SEARCH keywords "P0171 P0174 PCV Elbow"
Steve
Tyler Roberts
1997 - 2003 F150
Sep 22, 2014 12:40 AM
Daniel Smith
1997 - 2003 F150
Apr 4, 2014 11:07 PM
pete315
Apr 3, 2014 08:05 PM
NovaNewfie
1997 - 2003 F150
Mar 28, 2014 10:24 AM
ka1cu
1983 - 2012 Ranger & B-Series
Jan 20, 2002 08:10 PM
