Idler Pulley - ???
Old Aug 4, 2004 | 07:15 PM
n2howln's Avatar
n2howln
Idler Pulley - ???
I have an ’86 F250 with a 351 engine, no air. My problem is that I have a squealing pulley and have been unable to find a replacement pulley for the one I suspect is producing the noise. (I have replaced the belt.) After visiting just about every auto parts store in town and ordering (and returning) many pulleys, I am beginning to suspect that the pulley that is installed is not the right pulley. The 351 has two belts; the pulley I’m trying to replace is on the front most belt driving the air pumps and water pump(?). I think it is the idler pulley. The pulley installed on my truck is about 3 inches OD, with a ½ inch bolt hole, and is about 1.25 inches wide. It is not mounted on a bracket, but is bolted directly to the engine. My question is, is this the correct pulley. If not, can you describe the correct one and when it can be ordered?
<o></o>Any help will be greatly appreciated.
<o></o>
n2howln
Old Aug 4, 2004 | 08:55 PM
locknkey's Avatar
locknkey
Go to a junk yard whereyou are an do a search for the same make an model an engine you have and compare the difference...I would bet its the wrong pully and bracket...
Old Aug 5, 2004 | 05:38 PM
bremen242's Avatar
bremen242
<o></o>
n2howln
dude- can you take a picture of your air pumps & pulleys? I need to put my AIR system back together (thanks to the prev owner).
I think you will have to order that from ford. I am in the same dilemma. I am assuming it is a serpentine type pulley, and not a v-belt pulley?
Old Aug 5, 2004 | 07:12 PM
n2howln's Avatar
n2howln
Yes, the pulley is associated with the serpentine belt, however the pulley currently installed has a smooth surface, and the back of the belt passes over the pulley. I’ve been told by a ford dealer that the “correct” pulley is no longer a dealer product, and as I noted, I’ve had no luck finding the pulley through the after market. I’ve been to several junk yards junk yards in the area (but not all), also with no luck. I can take pictures of the air pumps & pulleys and post them on a web site Friday evening or Saturday morning. I’ll let you know when I get them ready.
<o> </o>
Good luck
and thanks locknkey.
<o> </o>
n2howln
