Radiator trouble...
Old Aug 4, 2004 | 03:24 PM
Hardball's Avatar
Hardball
Angry Radiator trouble...
I bought my 1979 f250 with orginal 351m seven years ago. after a week, the original radiator expanded on the top and popped a little pinhole. It had the original cap. I bought a new raiator, a 170 thermostat, and a 12 lb cap. No less than a month later, this one popped just like the last. ****ed off now, I just drive it and top it off. Well, now I got a six inch long speration between the upper portion of the radiator, and the lower, where a seam was joined, I JB welded it, and I cant figure out what the hell the proiblem is, I now have a thirteen lb cap with a pressure release lever, which I use every time I shut my engine off. the truck normally runs cool to midrange, at idle she will heat up pretty high, so I never Idle her for long.... What lb cap should be on this radiator?? my dad said it should be like 6 or seven lbs. I cant find one, I am sick of dealing with this as it is my daily driver. She gets pinholes that shoot all over my power steering pulley, then that goes out. whay does this keep happening???
Old Aug 6, 2004 | 06:27 PM
Ultramagdan's Avatar
Ultramagdan
So, how old is your current radiator? I think your thermostat is too low and I think you do need to go back to a lower pressure cap.
Does your system have a overflow tank?
Old Aug 14, 2004 | 09:50 AM
Hardball's Avatar
Hardball
current radiator was 5 yrs old, yes system overflow tank, 13lb cap is what the manual recommends. and its in the shop right now, getting a NEW radiator, clutch, thermostat, timing chain/gears, and txfercase, tranny fluid change.
