body mount shims?
Old Aug 4, 2004 | 10:25 AM
fordtime's Avatar
fordtime
Question body mount shims?
Ok guys this is probably a stupid question but here goes.
I'm in the process of removing the body off the frame of my '79 f350
and noticed shims between the rubber bushings and the body.
Every mount has a different number of shims,I've been keep track of how many came from each mount.
Now when I go back together with the new bushings do I put all the shims back where I took them out of?
Does anybody now if the shims come with the body mount kit?
If they don't come in the kit where would I find them,as these ones are pretty rusty and don't want to use the rusty ones on the freshly painted frame, if you now what I mean.
Thanks Vince
Old Aug 4, 2004 | 10:32 AM
bettyfordsawhore's Avatar
bettyfordsawhore
body shims
hey vince the body shims do not come with the mounts but cupped washers can be used to replace the old
Youll have to shim the radiator mounts more than the cab
Old Aug 4, 2004 | 09:23 PM
mark a.'s Avatar
mark a.
I would not put any shims under it until you put it back together and see where you are. If all the mounts are good and the truck has never been recked it shouldn't need any shims under the cab.
Old Aug 4, 2004 | 09:32 PM
garypettengill's Avatar
garypettengill
Ford still carries the shims. Come in packages of 10. With all new mounts, set the cab in place and then shim the bed and radiator to it.
Old Aug 5, 2004 | 05:47 PM
ranger429's Avatar
ranger429
Yes you will figure out where you need the shim's when all the body panel's are back on. Some might need shim's for body alignment. When I put new mount's on mine I did not reuse any of the old shim's and all the panel's lined up fine.
Old Aug 6, 2004 | 10:39 AM
fordtime's Avatar
fordtime
Thank you guys for the input.
Maybe this rig has been wrecked before?
The body lines matched up before I started and there was 3 shims on the driver side rad support and 2 on the pass side rad support.
The cab has 2 on the front of the driver side and 6 on the front pass side, haven't got to the rear cab mounts yet.
I don't think there is any under the bed, at least it doe's not look like there is any.
Seems to me I might have to shim the cab up to the bed and then the front clip to the cab?
Thanks again, Vince
Mark 42
Jun 24, 2017 07:32 AM
Icefan71
1997 - 2003 F150
Apr 11, 2017 04:39 PM
winginit
Sep 28, 2015 05:55 AM
Rowberryade
19
Sep 24, 2015 08:56 PM
krisbmeyer
Mar 30, 2011 11:34 AM
