Sponsored by: Real Truck
4R100/E4OD the same trans?
Old Aug 3, 2004 | 07:22 PM
02sd's Avatar
02sd
Question 4R100/E4OD the same trans?
I need a 4r100 auto trans for my 2002 f250 superduty 7.3 diesel 4x4, I keep seeing the E4OD and the 4R100 listed on ebay, rebuilders, etc. for sale, are they the same trans?
Old Aug 3, 2004 | 10:31 PM
NoMo's Avatar
NoMo
I think they consider the 4R100 to be an "upgraded" E4OD. Not sure that I'd go from a 4R100 to an E4OD... the internal electronic controls are probably a little different. You might ask down in the transmission forum to see if anyone knows for sure.
Old Aug 3, 2004 | 10:51 PM
johnsdiesel's Avatar
johnsdiesel
From my understanding, a big part of that upgrade was the torque converter. I'm not sure I'd replace a factory part with a lesser part. The 2002 PSD is also putting out more power than the E40D had to handle in the early PSDs.
Old Aug 3, 2004 | 11:03 PM
wlihntr's Avatar
wlihntr
that is what i thought as well, upgraded torque converter,and i think i different pan. i also would only put a 4r100 in your turck
Old Aug 4, 2004 | 06:52 AM
iskybantilus's Avatar
iskybantilus
i agree. You will sometimes see it called an E4OD - 4r100 transmission. just make sure its the newer 4R100 version when you get one.
Old Aug 4, 2004 | 01:04 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Ive always heard the 4r100 is the heavy duty version of the e4od,stronger internals for hard use, Lightng, diesels,V10's.Its basically the same design.
kountzecobra
18
Jan 7, 2022 01:48 PM
10strokin
21
Oct 27, 2015 11:18 AM
Kyler7700
1997 - 2003 F150
Feb 25, 2015 06:16 PM
Nighteyez
Feb 3, 2015 10:38 PM
MONAVIERONJON
Apr 21, 2014 03:47 AM
