Fuel Pump for 223 engine
Old Aug 3, 2004 | 04:23 PM
joewider's Avatar
joewider
I'm looking for a fuel pump for my '64 f100 223 engine. The problem I'm having is that most of the new fuel pumps available have the hinge pin (that's the pin the the arm pivots on) exposed, and as a result it leaks oil. I can even take a punch and push the pin out with my hand! I've had two...both leaked oil, and the first one simply failed to operate after about 5,000 miles.
Any ideas where I can find a better new pump or a remanufactured one?
Thanks
Joe Wider
Old Sep 5, 2004 | 08:25 PM
John D.'s Avatar
John D.
223 Pump
Joe,
I've gotta '63 F100 with a 223 that had the same problem.
I've used several different fuel pumps over the years and they all leak oil to some degree. Some much worse than others. Sure keeps that side of the block messy.
If you've ever had the pan off or torn down your engine, there is a rod journal on the crank that swings within a fraction of an inch of the fuel pump opening in the side of the block. I think that rod journal is bathing the pump opening with oil everytime the crank comes around.
I considered fabricating a metal baffle to protect the pump while I had the engine torn down, but never tried it.
My solution was to install a pump block off plate on the block and install an electric pump underneath the truck near the gas tank.
John
Old Sep 8, 2004 | 07:40 PM
prb001's Avatar
prb001
Smile
macs ford parts offers a stock type fuel pump for 223's. part # B4A-9350-B i think is the right one. they state that it is stock type, so should work.
Old Jan 8, 2025 | 12:01 AM
Vegassteve's Avatar
Vegassteve
2nd Gear
Pump Diaphram installation
What's the trick for getting the hole in the diaphram stem to engage the pump lever hook? Having some trouble figuring it out, lol. I didn't rebuild the pump, just disassembled it to clean deposits and check the diaphram, so don't really have a good mental picture of the mechanism.
Old Jan 8, 2025 | 01:07 PM
Crop Duster's Avatar
Crop Duster
You might want to start a new thread since none of the guys you are asking have been on here for decades.
Someone on here may have had one apart. Most people just keep buying new ones until they find one that works.
nothercrash
Dec 31, 2024 05:13 PM
johnred
Jun 14, 2011 02:37 PM
BaugherGarage
Feb 11, 2009 06:08 PM
legacy76
21
Nov 14, 2008 01:31 PM
Kunami
1978 - 1996 Big Bronco
Jan 6, 2005 12:03 AM
