Need help!! Trying to find the casting numbers on my 360. I've looked all over around, behind, under and beside starter, and on the front of the passenger side block but to no avail. Only numbers I can find is the usual 352 by the power steering pump and some small numbers on the bottom of the oil filter housing. Posted this in the truck section also, any input would be greatly appreciated!
Yeah my 390 doesn't have a block code either but it has the date code. The heads and intake should have something though. Even some things like the fan, brackets and such have castings numbers.
Yeah, know all that, I was just kinda hoping I had a rouge Holman/Moody factory smallblock, stroker motor that somehow escaped the testing grounds. I'll keep dreaming!!
