pressure guage
Old Aug 2, 2004 | 07:05 PM
DT 466Man's Avatar
DT 466Man
pressure guage
I have an 85 F150 300I6
where can i put my mechanical oil pressure sender on my engine
i would like to keep my original guage as well working
Old Aug 2, 2004 | 07:54 PM
MSC's Avatar
MSC
I just put an aftermarket mechanical oil pressure gauge on my 86 300 I6. I used a piece of 1" long 3/4 brass tubing from the block. I put a brass "T" on the end of the tubing and put the factory sender and new oil line to the gauge on that. I put the "T" on so that the factory sender sticks straight out from the end, and the oil line comes off of the side of the "T". Works great, I've done a few oil gauges that way. My 74 F100 didn't have factory gauges, on the "T" I put a oil light sender with the pressure gauge sender. I also did the same thing on my wifes 87 T-Bird, she wanted to keep the oil light with the gauge I added. Bought the brass pieces from Lowes.
Mark C.
Old Aug 2, 2004 | 09:02 PM
DT 466Man's Avatar
DT 466Man
ok thanks i guess that will work
so the oil sendr is the only place you can put a sender then
Old Aug 2, 2004 | 09:28 PM
5_labsownus's Avatar
5_labsownus
That is what we did years ago with the idot lights!
Old Aug 3, 2004 | 10:05 AM
DT 466Man's Avatar
DT 466Man
thanks i'll try that
Old Aug 3, 2004 | 11:08 AM
MSC's Avatar
MSC
DT 466Man I just reread what i wrote, i used 1"long 1/4" brass pipe. Sorry.
Old Aug 3, 2004 | 03:06 PM
andym's Avatar
andym
I've done this, too, but let me add a tip. I had lots of oil leaks with the brass fittings. Brass is supposed to be self-sealing - yeah right! I bought a tube of red threadlocker and put it all back together. No more leaks.
Old Aug 3, 2004 | 05:00 PM
MSC's Avatar
MSC
I use teflon tape, and never had a problem. Always use some sort of sealer before you put it together.
