Sponsored by: Real Truck
front end noise
Old Jul 31, 2004 | 07:40 PM
mck2000's Avatar
mck2000
front end noise
just notice my truck making a noise like a front wheel drive cv joint. when i turn ethier right or left .its in two high.im thinking front axel u-joint anyone else have thi happen to them thanks
Old Aug 22, 2004 | 08:33 PM
mikeyG9's Avatar
mikeyG9
I just noticed the same noise. Mine is only when I turn left (for now). Going in for warranty service for an exhaust leak so I'll have them take a look at the front end too.
Mike
Old Aug 23, 2004 | 08:46 AM
Big Orn's Avatar
Big Orn
The thing to keep in mind here is that if you have the tcase in 2Hi then the front axles are not turning. That's not to say that the ujoint will not "make a noise", but it's not likely unless it is completely demolished and falling around inside the yoke like loose change --
I would suspect the ball joints. Lift the front and give the wheels a good shake. Make sure you have the wheels chocked and the diff resting on good stands - you may need to climb under there and get your eyes on the ball joints to tell.
Good luck and let us know what you find.
Old Aug 23, 2004 | 11:03 AM
mck2000's Avatar
mck2000
took mine in they replaced both hubs and upper & lower ball joints
Old Aug 23, 2004 | 01:46 PM
Big Orn's Avatar
Big Orn
Hey Mark,
I just noticed your first post's date. Wow, where was I back then?
Glad you got it fixed, though and thanks for the reply.
Old Aug 23, 2004 | 04:05 PM
mck2000's Avatar
mck2000
yea, i thought i posted for myself but alls fine here .
Old Aug 23, 2004 | 04:20 PM
Big Orn's Avatar
Big Orn
