Power Window Motor
Old Jul 31, 2004 | 04:19 PM
randallc's Avatar
randallc
Power Window Motor
Hi all,
How easy is it to change a power window motor on a 1990 F150?
If anyone has details or what I should watch out for when I am doing It, I would appreicate the help.
Thank you
Randall
Old Jul 31, 2004 | 05:18 PM
dcrewchief's Avatar
dcrewchief
in order to get the old motor out you will have to drill some holes in inner door panel to get to the bolts or take it out as an assembly, replace motor and reinstall. at least that was the way it was on my 93 F150
Old Jul 31, 2004 | 06:44 PM
GypsyR's Avatar
GypsyR
It's not too bad. Like Crewchief said, you need to drill two holes. Once you get the panel off and the plastic out of the way, look at the lower front of the door. You can see one of the 8mm bolts that holds the motor to the regulator. The other two bolts are located by two "dimples" in the door metal. Use a largish drill bit and drill out the dimples. A bigger hole than you might guess is needed because the bolts are never quite exactly lined up with the dimples. Use a stick (or a friend) to hold the glass up, unplug the motor, and unbolt the motor. Reverse to install the motor. The glass doesn't have to be in any particular position but you might have to wiggle it up and down a bit for the motor to seat all the way in. That's about it.
What bothers me is that if Ford thought to put the indicating dimples there, why the heck didn't they just go ahead and punch two holes instead?
Old Jul 31, 2004 | 08:48 PM
dcrewchief's Avatar
dcrewchief
I agree it would make the job a little easier. i took mine out as an assembly so it wasnt too bad. the trick was too snake the assembly in and out. i really wonder how some of these engineers get paid for their ideas that really suck.
Old Jul 31, 2004 | 09:10 PM
Peach's Avatar
Peach
yeah i ended up drilling holes on my '87, then later looked to the left and realizing the previous owner had already drilled 2 holes.oh well
Old Aug 1, 2004 | 10:21 PM
randallc's Avatar
randallc
Thank you guys! All your help is great.
Old Aug 1, 2004 | 10:40 PM
MemOrex's Avatar
MemOrex
i need to that too, but my motor is fine. its some gear thingies that wore out or something cuz i have to help my window up.
Old Aug 1, 2004 | 10:45 PM
randallc's Avatar
randallc
Mine just stops working after its been sitting in the sun for a few hours. If I take the door panel off and give the motor a smack with a pipe it will start working again. I have put up with it for 2 years now, I think I will replace it
Old Aug 1, 2004 | 10:50 PM
MemOrex's Avatar
MemOrex
lol, i tried the good 'ol giving it a smack, but it didnt work . even tried greasing the heck out of it.
Old Aug 2, 2004 | 02:31 AM
kinnja's Avatar
kinnja
Hello,
Here is my response to a similar post not too long ago:
Originally Posted by kinnja
On my 1990 f150, there are three bolts holding the motor in place. Only one of them was accessible, but the locations of the other two were marked by dimples in the sheet metal of the door. For one, I drilled the sheet metal out with a 3/4 inch drill bit, for the other one, I used tin snips.
In my case, the motor was still good, it was the plastic gears that were bad--it worked like new after replacing the gears.
I replaced all of the door Panel Retainers before I put the door panel back on because even the ones that weren't broken were stiff and brittle. The generic ones for Ford/Dodge/Chevy worked fine even though they were slightly different lengths (it was all they had in stock).
When I was putting the door panel back on, I had to raise the interior door handle to the up/open position, and I had to pay special attention to make sure the door lock ***** didn't get wedged against the underside of the door panel.
The first parts store I tried didn't have the motor or the gears in stock. The second said they had both, so I bought a new motor, which included the gears. The motor they sold me didn't fit, it looked different, and had a completely different bolt patern, so I took it back and just bought the new gears.
Replacing the plastic gears, which had pretty much disintegrated worked just fine.
Old Aug 7, 2004 | 03:54 PM
04Aviator's Avatar
04Aviator
Smile My experience with worn out gears..
1st, there is a difference in the gear kit (not sure about the motor) according to date of manufacturer. I replaced mine (92F-150) and the I had to tell them whether it was manufacutered before or after May 1st of 92 .
The help on this post made my replacement an enjoyable 1 hour to replace the gear on both windows..
One tip though, make sure you have a strong magnet you can fish down in the door to retrieve the one or two bolts you will almost surely drop. A magnetic 5/16 socket really helps to...
Old Aug 7, 2004 | 07:46 PM
MemOrex's Avatar
MemOrex
Well, i did the job like 2 days ago. not as hard as i thought. man, when i opened the gear cap/top all these broken plastic things fell out. they were the worn out plastic/nylon things. just bought them and put them in and works like new. lol 04Aviator, you will drop at least 1 bolt, except i didnt use a magnet, i stuck my hand throught the speaker opening (Ouch).
