Bronco II Ford Bronco II
Explorer front springs
Old Jul 31, 2004 | 12:12 PM
rguy's Avatar
rguy
Is it possible to swap the Explorer front springs into the B2? If so, I wonder if I'd gain a little lift out of it.
Rob
Old Jul 31, 2004 | 01:48 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Yes it is possibe .Thet fit right on the BII and will give you about 1-2 inches of lift the same a the rear swap.improves ride and handling also.
Jeff
Old Jul 31, 2004 | 03:30 PM
rguy's Avatar
rguy
thanks. I'll add this to my junk yard grocery list.
Old Jul 31, 2004 | 10:41 PM
'87BroncoII's Avatar
'87BroncoII
with the explorer coil and leaf conversion will that affect your caster camber alighnment
Old Aug 1, 2004 | 10:58 AM
GrayRanger4x4
Yes. but a good alinement shop can ajust it with no problem.Most of the time its not needed with the spring swap.
Old Aug 3, 2004 | 01:35 PM
'87BroncoII
thanks i think im gonna get me a lift tommrow from my junkyard
Old Aug 4, 2004 | 12:22 AM
RomerB2's Avatar
RomerB2
ok im interested in this, what parts under the explorer do you need, and what kinda of tools should i bring along, and how hard would this be? i want to know what it will take to get them off and on to my 90 bronco II, you guys have been help with everything i have done, thanks so much, hopefully this will help me some too
