Sponsored by: Auxito
Drive Cycle for new engine install
Old Jul 31, 2004 | 07:20 AM
PCS's Avatar
PCS
I recently had a new engine installed in my '97 F150. When going to my local emission test station it failed and gave a 'drive cycle not ready' error message. After driving 125 miles the 'check engine 'lite came on. Autozone checked the code and it said 'EGR valve' was the culprit. I replaced the EGR valve. While under the hood I noticed my battery terminals were not greased. I like to grease them..so I disconnected the battery terminals ,applied the grease and reinstalled the battery cables. Upon start-up the 'Check Engine ' lite was out so I went back to the emission test station. Again, it failed with the 'Drive cycle ' not complete code. Does anyone know what the drive cycle is , (a Ford rep told me between 60 -75 miles). I think this had something to do with me disconnecting the battery which ultimately led to the Check Engin lite to extinguish.
Old Jul 31, 2004 | 08:14 AM
rtjohnson1964's Avatar
rtjohnson1964
generally speaking most 96 and newer vehicles OBD-2 /drive cycle = 2 trips 50 miles each trip
next which code did you get at Autozone?? P0401 by chance P0401=EGR insuficient flow
OK, disconnesting the battery, reset your computer IE(same problem as before) drive cylce incomplete. as far as the check engine light coming back on there is still a problem(RECHECK FOR CODES) post them and i will try to help you through it.
Old Jul 31, 2004 | 09:51 AM
Racerguy's Avatar
Racerguy
Make sure that when you do the drive cycle that you vary your speeds and do some stop and go type driving too.
And hi rt and welcome to the forum
