Sponsored by: Auxito
Mass Airflow Sensor
Old Jul 31, 2004 | 12:20 PM
Shootit's Avatar
Shootit
Mass Airflow Sensor
Somebody tell me where the mass Airflow sensor is on a 5.4Ltr and how hard is it to change out O2 sensors. Thanks a bunch.
Old Jul 31, 2004 | 02:28 PM
rtjohnson1964's Avatar
rtjohnson1964
97-2003 the MAF is located in the intake side of the air filter housing, unclip the two
halfs of the arfilter housing,look inside the part of the housing on the engine side you
you will see a metal peice in there. that is the MAF.
AS far as replacing the Oxygen sensors (O2 sensor) they aren't real bad to replace, the hardest one is the pass front sensor due to the location of the electrical plug(clipped to the back of the cyl head)not easy to access
