Transfer Case Shift Motor Question?
Old Jan 10, 2002 | 08:29 AM
dinograd's Avatar
dinograd
I have a '94 XLT w/ automatic transmission. I'm goin junk yard huntin for a transfer case shift motor for my truck, does anyone know what years of trucks use the same motor? I plan to buy within the next month or so, but I don't want to limit my search to just 94's if other years are using exactly the same motor. Thanks for your help.
-Keith
Old Jan 17, 2002 | 09:15 PM
hd1's Avatar
hd1
Depending on what case you have, if it's a 3156 you should be able to use the motor off of a 1988-1994 Ranger,BroncoII, or Explorer.Hope I was of some help. HD1
Old Jan 18, 2002 | 08:16 AM
dinograd's Avatar
dinograd
How do I figure out what model number my transfer case is?
Old Jan 18, 2002 | 07:45 PM
hd1's Avatar
hd1
On the backside of your case towards the bottom, there should be a little tag , on the tag in the lower right side has a couple of letters and then a number- the number 3156 , 4405 4406, etc. denotes the trans.case type. If this dont help check out your local Ford garage.Any good tech.can get you pointed in the right direction.Good luck!!HD1
Old Jan 18, 2002 | 08:01 PM
wildcrisps's Avatar
wildcrisps
